headlight switch
mitchbowers
Ohio
1996 2500 5-speed, soon to be leveled on 33's
5.9 Magnum
alright..headlight switch.. it's being a real pita let me tell you.
so I'm still having the same problems as I did before, even with replacing the female adapter that plugs into the switch itself- which had to be done when I saw what happened to the old one
NOW. headlights and fogs will come on at the same time(cabs&running lights as well, obviously) but only when the new switch is in between fog and headlight. but when you pull it all the way out, it won't let the fogs&etc come on. SO-thoughts?
Sent from my XT1575 using Tapatalk
mitchbowers
mitchbowers
Ohio
5.9 Magnum
dimmer switch makes no difference on it. I'm really at a loss myself.
dudeman2009
Magnum 360
Is your truck the sport or non-sport edition? Are all your lights still halogen?
mitchbowers
mitchbowers
Ohio
5.9 Magnum
non sport, but pre 98 so that shouldn't matter. my heads, fogs&cabs are all leds. so are taillights, but those are led housinga
pajeepman
SE PA
5.9 magnum
Bad switch? Even if it is new, it could be bad.
Sent from my SM-J320P using Tapatalk
Novia
El Monte, CA
Hemi 6.1
change another switch or check out your wire, maybe somewhere loose.
lasse452
