Driftless Ram
- Jun 11, 2014
- 3
- 0
- 2001
- 5.9L 360Cu. In. V8 GAS OHV Naturally Aspirated
I've got a 2001 Ram 1500 Sport 4x4 5.9 Magnum V8 Automatic, fuel injected..
It won't start. There's a laundry list of things I've replaced, and I'm stumped. I live in Wi, so it's very cold.
What I've done: Replaced Plugs, Wires, Cap, Rotor. Replaced CPS, tested Cam position sensor (good). Replaced IAC. Cleaned TB, Tested Alternator and battery (good)
What I haven't done: Anything fuel related.
What it does: Cranks normally then sputters out. Makes a loud PFFFFFFFFT noise that comes out of the top of the Throttle Body with a puff of vapor/smoke. Ive even seen flames. Although that is uncommon. All that back-gassing now has soiled up the new IAC and TB.
I can't keep replacing things, and spending money not knowing what it is. I've been 2nd guessing my work, and dbl checking everything I've installed. Not fun. There are no codes that come up either.
At a loss currently and I live rurally far away from any repair shop. So that's an expensive trip. The whole fuel tank "pill" that has the pressure gauge/float level, pump kinda scares me. I don't want to go down that road. And the fuel pump works, it's loud but operates, and fuel spurts out of the presta valve on the fuel rail with key off, and more-so with the key on..
Would appreciate any ideas or help, and links. Although I feel like I've seen most of them ad nausea. Sorry if my format's not right, I am a noob here. Thanks!
