So I have been searching the forums for the answer to my question with no luck.
I am going to have the honor of trying to join the changed my ram hub bearing club. From what I see there are 2 possible bearing styles available, one each for 2 or 4 wheel abs. On my '97 Cummins 2500 I seem to have 4 wheel abs as there is a pickup and tone ring mounted inside the knuckle. My quandary is that that neither seem to be part of the bearing as the tone ring is attached to the outer axle half shaft? So which bearing do I use and what is the actual difference in the two if mine doesn't seem to have abs sensor built in?
Thanks
Thanks
