Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Tech Info
Tech Info
Losing coolant.. Please help!
This is a discussion on Losing coolant.. Please help! within the Tech Info forums, part of the 2nd Gen : 1994 - 2002 category!
08 ram 1500 158k 5.7 Losing about 5 inches on the reservoir every week or so only driving approx 15 ...
Reply
Old 01-12-2017, 03:31 AM   #1 (permalink)
Ram Year: 08 Ram 1500
Engine: 5.7 Hemi
Default Losing coolant.. Please help!
Losing about 5 inches on the reservoir every week or so only driving approx 15 km per day. oil level and color looks good. Coolant in rad is pretty old but doesnt look horrible. seems to be wet on the sides of the rad near where it connects to all that plastic junk. more so on the drivers side. ( Rad is only about a year old it was replaced when i hit a deer. pretty much everything on the front of the engine was replaced) Truck seems to run fine,no white smoke out the pipe no excessive water. It's currently -20 -30 celcius I seem to have good heat in the cab. can't smell coolant while driving but i notice i can smell it sometimes when Im out front on the truck.
I have a bad fan clutch that will be getting replaced this weekend along with the water pump t stat and housing.
is it my rad?..i dont really see any leaking hoses..but i notice there are wet spots along the sides of the rad from top to bottom, near front bumper on the frame and sway bar. I havn't noticed any puddles or spots on the ground. again this has been happening for about a week and a half..around the time my fan clutch went.
sorry im a bit all over the place but i would appreciate some help.
Sponsored Ad
Register to remove this ad.
Bferguson is offline   Reply With Quote
Old 01-12-2017, 04:40 PM   #2 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
Get some fluorescent dye and put it into the radiator, auto shops should sell some that will work. Then wash off the radiator with some water and drive it for a bit. You can get black light pens pretty cheap, or if you have a worklight that takes a standard bulb, you can get blacklight bulbs for pretty cheap. Just look for the fluorescent dye.
Another option is to start tasting things
I'd give all those connections a good looking over, rev the engine up and down with your hand while watching each connection.
Old 01-12-2017, 04:52 PM   #3 (permalink)
Engine: 5.7 Hemi
Default
Thanks. ill give the die test a go this weekend if i can find me a black light!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
A/C losing refrigerant F22-Raptor General Discussions 12 09-02-2016 04:11 PM
Air/vibration in engine, losing coolant and mpg. Please help rhoadsrocker Engine & Performance 2 08-01-2015 08:32 AM
Coolant leak/coolant temp? Gottobecdn Engine & Performance 3 10-09-2014 11:07 PM
losing control justin443 Towing & Hauling 26 09-29-2012 08:29 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
