Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Tech Info
Tech Info
Manual Tranny Whine while coasting
This is a discussion on Manual Tranny Whine while coasting within the Tech Info forums, part of the 2nd Gen : 1994 - 2002 category!
I recently got an 01 1500 5 speed. I believe it has the NV4500 transmission. Anyway it shifts fine, drives ...
Reply
Old 09-26-2016, 12:04 AM   #1 (permalink)
Ram Year: 2001
Engine: 5.2 Magnum
Default Manual Tranny Whine while coasting
I recently got an 01 1500 5 speed. I believe it has the NV4500 transmission. Anyway it shifts fine, drives great, until I let off the throttle. As soon as I loose positive power it starts to whine. Not a grind, just a noisy whine. Sometimes it lurches a touch. Anyway maybe related it had a pretty bad transfer case output seal leak, and after getting the truck I checked the levels and it was REALLY low. Fixed that and it seems to be better than before. Any thoughts? Thanks a ton guys.
Sponsored Ad
Register to remove this ad.
TheBlackMambaXD is offline   Reply With Quote
Old 09-27-2016, 02:10 AM   #2 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
My truck is neither manual or 4x4, however I have quite a bit of experience with 4x4 systems on chevys, and manual trans on Semis.
Seeing as the noise quieted down after filling the transfer case, and you determined it to be low, it is likely that is where a majority of the noise is coming from. If it was run too low on oil, the clutch assembly may be the source of the noise, primarily the bearings on the dog (assuming that dodges use a dog and not a friction type clutch in theirs) The chain may also be a source of some whine due to lack of lubrication if the front driveshaft isn't disconnecting.
Just fill the transfer case to the proper level with ATF+4 transmission fluid. Do not put any additives in except those specifically listed by Dodge.
A bit of whining can be expected from the manual trans, most of this is just gear noise. For most of the transmissions life power and rotation are being applied primarily in one direction, the direction that moves the vehicle forward (the output shaft and countershaft are the only ones that reverse direction under normal forwards and reverse driving, the input shaft always spins the same direction) Less than 5% of most transmissions lives are spent in reverse, and then only the reverse gear on the input and countershafts as well as the idler gear see any load, the rest are relatively unloaded. When two metal surfaces meet and rub against each other, they wear in a specific pattern. This pattern wears in such a way as to provide the most contact between the two gears, this results in quieter and more reliable operation. Because all of these gears only ever see load in one direction (given that no engine braking has ever been done on the transmission, the clutch is either engaged or its put in neutral) only one side of the gears ever wears together. When you coast in gear with the clutch depressed, the gears for the range selected are now being driven by the drive shaft instead of the engine, this forces the 'non-mated' sides together and can cause quite a bit of noise. Even if you put it in neutral, the selector only disengages the input shaft from the gears on the input shaft. All the gears are still being driven by the drive shaft, there is just slightly less 'load' on them from the input shaft bearings. Coasting in gear with the clutch engaged, also know as engine braking, will result in quite a bit of noise even in a high gear where the engine may only be at idle speed as the drive shaft is now backdriving the engine, and all the friction from the engine systems is putting load on the gear range selected.
I wouldn't worry about the trans, just make sure its filled up. As for the transfer case, if you want, you can do a fluid change to remove any debris from it (I have no clue if it has a filter, I would expect that it does, but I don't know) that may help. However, whatever damage has been done, is irreversible. As best, it just has a reduced service life, at worse, the bearings are damaged and may cause premature failure under high load. You will know if the bearings are bad or going bad though, the noise will get continually worse. But a little bit of whine is expected, just not so much that it sounds like a Honda backing up.
Old 09-27-2016, 09:26 PM   #3 (permalink)
Ram Year: 2001
Engine: 5.2 Magnum
Default
Haha thanks, didn't expect such a detailed answer. I've had the truck just for a few weeks, and I've already fixed the leak and filled it up with ATF. And it really could be that the previous owner didn't do much engine braking. Me I live in the hills so I engine brake constantly, and notice it constantly. X). BTW the transmission was filled to the plug with oil.
__________________
Stock 2001 Dodge 1500 5.2 Magnum
Old 09-27-2016, 10:44 PM   #4 (permalink)
Engine: Magnum 360
Default
Just dont beat the piss out of it like those Ford boys and it will last a good long time. Its funny too, most of the older fords around me are all beaten down and just piles of garbage, run like a half dead cow too. I don't see any old chevys. But there are a lot of old Dodges that look good and run great, thats gotta mean something.
Good luck to ya
Old 09-27-2016, 10:57 PM   #5 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Dude, ?. ATF4? Does the transfer case really give a shit? Just thinking cost wise. I used regular Dex III in my 01 T-case.
__________________
I've done more stupid sh#t as an adult than I ever did as a kid.
Trudeau & the NDP.
daylight savings. Leave the clocks alone.
NO TO BILL 6.
Jimmy68 is offline   Reply With Quote
Old 09-28-2016, 09:04 PM   #6 (permalink)
Engine: Magnum 360
Default
It may not. But I do things by the book, if the service manual specifies a certain type of fluid, thats what I use. Could you use any type of anti seize on brake components, sure, but high temp anti seize it proper albeit slightly more expensive.
The exhaust stack on Semis specify grade 8 bolts, do they need that, not really they could get away with grade 5, but grade 8 is whats specd out.
As far as cost goes, I know i'm not as knowledgeable as the engineers who designed these things, when they specify something there is usually a reason. Sometimes there isn't and its solely for convenience, but i'm not qualified to make that determination. One fill of ATF+4 is worth both the peace of mind and the avoidance of potential problems down the line.
Just my 2 cents.
Old 09-29-2016, 04:12 AM   #7 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Atf is best if you wish to avoid potential problems. Pretty sure the main concern is with the auto trans if the seal between the 2 should ever fail you're buying a transmission.
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, CarvenTR, M1 91 Octane canned tune by FlyinRyan, 4.56 gears+Eaton TrueTrack remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Manual Tranny Whine while coasting TheBlackMambaXD Engine & Performance 0 09-24-2016 04:45 PM
2014 sport 8speed cold temp tranny whine redblack General Discussions 17 07-22-2015 04:00 PM
5.9 Into a Ram with Manual Tranny Txdrewski Engine & Performance 7 11-12-2013 02:14 AM
18k lb towing, manual or auto tranny? mhays Towing & Hauling 15 06-21-2013 12:45 AM
2012 ram sport W/manual tranny??? MvZiC MaN General Discussions 36 10-01-2012 01:38 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
