Map sensor?
MoparMagic'00
Arkansas
5.2 Magnum
Hey guys ive got a little issue on the ol girl.. 00,5.2,Auto,4x4,
It sucks alot of ait very noisy but its not really consistant.. It also idles higher then like a choke is on (carburated style), it also idles higher then as well around 1100. I replaced the iac last year and a few weeks ago took the tb off to clean it all removed all sensors, inspect o rings etc..
Sent from my LGL41C using Tapatalk
tommyboi87
houma louisiana
5.2 Magnum
When did it start doing this? Did you mess with the pintle on the iac sensor when you took it off to clean it? Was the tb gasket changed?
Sent from my SAMSUNG-SM-G925A using Tapatalk
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I don't think a MAP sensor would cause that....but idk
tommyboi87
houma louisiana
5.2 Magnum
Iac would, right? Especially if he moved it any or didn't put the o-ring? Or if the tb gasket is no good..
MoparMagic'00
MoparMagic'00
Arkansas
5.2 Magnum
The pintle was cleaned very carefully o rings good and tb gasket new.. Was doing this last year and why i put new iac on it...
MoparMagic'00
MoparMagic'00
Arkansas
5.2 Magnum
Checked those with carb cleaner
tommyboi87
houma louisiana
5.2 Magnum
Did you try spraying some around the intake manifold where it bolt to the heads? Could be the gasket which is a guaranteed fail at some point.
MoparMagic'00
MoparMagic'00
Arkansas
5.2 Magnum
I think the plenum is blown but the outter gaskets when i sprayed all seemed fine as in no change in running while i sprayed..
1Popeye
