Dodge girl 76
I have a 96 Ram 1500 5.9 and it just shut off on me. It cranks and will spit and sputter and just shut down. I'm on my own here and really need my truck to run.
Welcome to RF!
Questions like yours will get a pile of questions, and many opinions and/or ideas. This is one of those "it could be one problem or several" threads.
First lets start with the obvious. Did it throw a CEL...orrrr has had one that hasn't been checked? Or it's been checked but ignored. If so it would be good to know what that is.
Does the fuel pump run when you turn the key (not start) to on? You should hear it whine for a couple of seconds.
Do you smell gas anywhere?
Does the truck start if you hold the gas pedal to the floor, then shut down when you let off? Does it stay running if you keep your foot on the gas but the engione won't hold curb idle? That could be an IAC (idle air control) on the back of your throttle body.
Now, your truck has a crank sensor on the back of block on the passengers side. Sometimes these fail without warning. This will cause a no start issue but allow the truck to crank. Same symptoms with the cam sensor which is in your distributor, but these rarely fail.
