2000 ram sport. 3.55 rear end. I am working on repairing the rear end and am having some issues. Thought somebody could help.
I have damaged the spider gear shaft, top n bottom spiders which led to missing chunks of teeth on ring and pinion gears. So far i have pulled spiders and axles but cannot gdt main rear gears out. Bearing caps are off and rear is loose but wont come all the way out. Pinion shaft is also loose. Any help on getting the gears out and what caused the spider shaft to break...twice?
