Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Tech Info
Sponsored Ads
Register to remove these ads.
Tech Info
pitman arm replacment.
This is a discussion on pitman arm replacment. within the Tech Info forums, part of the 2nd Gen : 1994 - 2002 category!
Register to remove these ads. It's free! So I am buying my buddies 97 ram 2wd . He let me ...
Reply
Old 01-19-2012, 02:26 PM   #1 (permalink)
Ram Year: 1997
Engine: 5.2
Default pitman arm replacment.
So I am buying my buddies 97 ram 2wd . He let me check everything on it and the only thing it needs is a pitman arm and the tensioner makes a clicking noise. Its been making that noise for almost a year. The pitman arm has a little side to side play. Honestly if it didnt have to be inspected I wouldnt worry about it. So tell me is it as easy as it looks? Bolt out of drag link, bolt off pitman arm and use the little puller to pop it off. The use a hammer to tap the pitman arm back on then bolt it up and your done? Is that right? Ive never done one on any truck but i believe that's right. Tips and tricks are welcomed. My buddy said he would do it if I bought the part but im going to tune it up and oil change and just do it myself so I can bond with my new truck. Thanks guys :-)
dakota1820 is offline   Reply With Quote
Old 01-19-2012, 03:04 PM   #2 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
I honestly think its the steering gear box.
__________________
2001 RAM, 5.2l, 5" LIFT, 33" BFGs, 100 wt yellow fogs, all base model
rambob is offline   Reply With Quote
Old 01-19-2012, 03:07 PM   #3 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
here is a write up (NOT MINE)
Pitman arm removal and replacement
For those of us who suffer with sloppy steering with our Dodge trucks, there can be many causes. One of the most common cause of the sloppy steering anomaly, is a worn pitman arm. I get the sense from talking with other Dodge owners, that pitman arm wear is not really consistent. Some wear out quickly, while others get huge miles out of theirs. As with any moving part, those that maintain repair less. Keeping the entire steering linkage well greased is the main key. Every 5k miles is the maximum I would go between greasing. Grease is easy and cheap, don't be penny wise and pound foolish. The following pictorial was done on a 1999 Ram that was in the shop for a pitman arm replacement. So follow along as we tackle this relatively simple job.........
These are the tools you will need for this job. I rate this job a 3 on a 1-10 scale. You may need some tools you don't have like a pickle fork, pitman arm puller, and a 1-5/16 socket.
Here is a shot of the worn out pitman arm. The symptom was too much play in the steering wheel. An easy test is to have someone very slowly turn the steering wheel back and forth just a little, while you watch the steering box and pitman arm. A bad pitman arm will move with the steering box, but wont move the center link. Just a few degrees of rotation on the steering wheel is all that is needed. The pitman arm is what wears NOT the center link.
We start by removing the cotter pin and securing bolt on the junction of the pitman arm and center link.
Next we remove the bolt on the steering gear box that is below the pitman arm.
Now we take our pickle fork and 3 pound hammer and insert is between the pitman arm and center link.
After a few well placed and motivating whacks with the hammer, the joint will pop free.
Next we will set our pitman arm puller on the arm and steering box shaft. I tightened up the puller very tight and gave some very firm but NOT hard blows to the end of the pitman arm. ** You must be very careful hitting against the gear box so as not to damage the shaft seal or worse, bend the output shaft. Just taping on the pitman arm does 2 things. It help to break the rust bond that has formed and relives the stress on the pitman arm. You will have to do this several times. Tighten further a little bit, then tap with hammer. This one took 4 cycles before it came off. If you try to hammer on it with an air impact gun, you may end up breaking the puller. Be patient it will come off.
The pitman arm is now starting to come off the output shaft.
Pitman arm removed and compared to the new one. Looks just the same as the new one except dirty but........
A close-up of the old shaft reveals the cause of the wear. See below the threaded portion of the joint. There is some circular wear marks there. Cause of this.......improper lubrication!
Now just transfer the old zerk fitting to the new shaft if it does not come with one. Assembly is the reverse of what we just did. Just remember the center link will have to be pulled toward the pitman arm with your hand, when you install the new one. They have a tendency to flop around after the arm is removed.
A new arm and no more steering slop. Remember to tighten everything well and install the cotter pin back.
__________________
Old 01-19-2012, 05:36 PM   #4 (permalink)
Ram Year: 2000
Engine: 5.9
Default
does the arm only go on one way to the steering box or can you get a couple teeth off in either direction on steering box?
dirtracer is offline   Reply With Quote
Old 01-19-2012, 05:42 PM   #5 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
I have not done a ram, but I believe yes. it could be installed and not be centered.
__________________
Old 01-19-2012, 07:23 PM   #6 (permalink)
fla crkr 1 ton's Avatar
Ram Year: 1998
Engine: 5.9 cummins 12 valve
Default
No you can't put it on wrong it is murphy proofed the splines have a wide groove [index] in one spot so it only goes on one way.
__________________
Redneck engineer'in beat ta fit paint ta match!!
1998 ram 3500 cummins dually
1966 plymouth barracuda 273 cid auto
2011 mustang v6 305 hp 6 speed manual
2006 volkswagon jetta 2.5
USAF Aircraft Mechanic 1979-1989
fla crkr 1 ton is offline   Reply With Quote
Old 01-19-2012, 07:59 PM   #7 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
Good. Thanks for the post
__________________
Old 01-19-2012, 09:46 PM   #8 (permalink)
ramhunter9's Avatar
Administrator / Owner
Ram Year: 1994
Engine: 7.5L
Default
Yup , only one way
__________________
RamForum.com Administrator/Owner/Vendor
Click the link for info
DB Truck Customs Facebook Page (Click Here)
dbtruckcustoms@gmail.com FOR ALL YOUR PARTS NEEDS or installs email/PM me for a price quote. If you want it chances are I can get it at a very good price ! Web Sight Coming Soon !!
ramhunter9 is offline   Reply With Quote
Reply
Bookmarks
Tags
2nd gen pitman arm, dodge ram pitman arm, pitman arm replacement
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
