TruckFukd
- Oct 23, 2014
- 3
- 0
- 1998
- magnum 5.9
Ok so i am new to these forums and i have virtually zero mechanical experience but ive got an issue id like to try and take on myself. i have a 1998 dodge ram 1500 and as i was slowing braking the other day i felt the brake peddle lose pressure and kind of sink to the floor. my brake light and ABS lights came on and i did not have much braking power. when i checked the brake fluid level there was none in there so i filled it up only for it to drain out again. when i got home i noticed brake fluid pooled around my rear driverside tire tho i cant see the direct source of the leak. i found one site that said it may be the wheel cylinder but i thought i would try out the forums and see if you guys may be able to offer any advice
