Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Tech Info
Tech Info
Slow brake pedal return
This is a discussion on Slow brake pedal return within the Tech Info forums, part of the 2nd Gen : 1994 - 2002 category!
I am new to this but need some help. I have a 99 1500 quad cab with a 318 and ...
Reply
Old 03-03-2014, 12:21 AM   #1 (permalink)
Ram Year: 1999
Engine: 5.2 318
Exclamation Slow brake pedal return
I am new to this but need some help. I have a 99 1500 quad cab with a 318 and a manual transmission I have recently been experiencing slow brake pedal return (anywhere from 2-8 seconds). After a little research and $250, I still have the same problem.
What I have done;
-I replaced;
Power booster
Master cylinder
Vac. hose from intake to booster
-I bled the brakes )furthest from the MC to the closest
-lubed the pivot the brake arm is attached to
-scratched my head.
Some reading was telling me the booster was bad so that is why I replaced that. a little more reading and locals said it sounded like a bad MC so I replaced that. What clued me onto this was braking at a stop sign, letting off and seeing my trailer brake controller was on (normally is when brakes are applied). Thinking this was odd, I lifted the brake pedal with my foot to see if the light would go off and it did. I remembered my parents had the same issue on their 99 durango but don't remember what fixed it.
Never the less, over the last few weeks, I have dealt with the pedal slowly returning but enough is enough, I want it fixed. Camping season is coming, as soon as the snow melts.
A few people have said to adjust the light switch but that wont speed the pedal return up and others have said a spring but again, something must be wrong for the pedal to act like this.
I have recently read something about the the rear brake pistons????? is this a sign of worn brake shoes in the rear??
Like I said this was a sudden issue. One day all was well and the very next the problem started.
Please help me out folks. I know there is a lot of great info out there and surely someone has experienced this before me. Funny thing is all the Dodge dealerships, Les Schwab and other brake repair shops have all said either they have never seen or heard of this or it is common for the Dodge brake pedal to return slow. They don't understand when I tell them this is just no occurring which is why I was calling.
I am not afraid of getting a little dirty to replace something if need be, just not excited about dumping more money into something that might not fix the issue.
Thanks all!!!
Sponsored Ad
Register to remove this ad.
991500quad is offline   Reply With Quote
Old 03-03-2014, 12:29 AM   #2 (permalink)
dodge dude94's Avatar
Ram Year: 1998 Ram 1500
Engine: 5.9 Magnum
Default
Never had that issue but I have had pretty much my entire braking system replaced.
I had a bad MC, went to the shop, and ended up going through 2 more MCs before a new one was purchased and installed. So a reman MC being bad isn't out of the running.
My truck failed the brake test during inspection one year, so I had a new booster installed, passed inspection and brakes felt better. However, when I got the plenum replaced later that same year, my pedal feel was even more better after that. You should also pull your drums and make sure the linings aren't worn and your wheel cylinders aren't leaking. The rear brakes contribute hugely to pedal feel.
Hope you get it figured out and welcome to RF.
__________________
1998 Ram 1500 4x4 QCSB, 360- ebay plenum, Cloyes 3028X, 14in Maggy, DIY CAI, DIY 50mm TB, TransGo shift kit, 285's, LED headlights, Ranch Hand Legend guardOctober 2014 - August 2015 TOTM Winner
dodge dude94 is offline   Reply With Quote
Old 03-03-2014, 09:06 AM   #3 (permalink)
Ram Year: 1999
Engine: 5.2 318
Default
I will check the rear brakes this weekend. That is the last part to check that I haven't touched besides when I bled them. Thanks for the info. I'll let you know if it works.
Old 03-05-2014, 08:57 PM   #4 (permalink)
Ram Year: 1999
Engine: 5.2 318
Default
I checked the rear brakes, they are still in good shape and the wheel cylinders and great with no leaks. Any more ideas?
Old 03-05-2014, 09:17 PM   #5 (permalink)
Engine: 5.9 Magnum
Default
Were they adjusted properly?
__________________
Old 03-05-2014, 10:04 PM   #6 (permalink)
leadrofthepak's Avatar
Ram Year: 1998
Engine: 5.2
Default
Even though the rear brake cylinders can appear to be leak free and fully functional, once removed you may find that they have no recoil to them at all. Both rear brake cylinders on my truck were like that when I bought it, dry as a bone and looked fine but once I took them out they were sloppy and dead, maybe blocked up or something. Word of caution: use a generous amount of penetrating oil on the line fitting if you are going to replace them. Replacing the lines is less than fun... at least from my perspective. I would also opt to replace the drum hardware as well, while you're in there and all.
leadrofthepak is offline   Reply With Quote
Old 03-05-2014, 10:33 PM   #7 (permalink)
Ram Year: 1999
Engine: 5.2 318
Default
Yes everything was adjusted great. I have read about the nightmares replacing the cylinders. I am going to do a little "tweeting" on the push rod on the booster first. Seems like the easier of the two. If all else fails, I will spend the few bucks on the cylinders. Will keep you all updated as I go.
Old 03-09-2014, 08:33 PM   #8 (permalink)
Ram Year: 1999
Engine: 5.2 318
Default
Well guys and gals I have put new wheel cylinders in, re bled the brakes and every thing is alittle better by not fixed. If I use full brake the pedal is somewhat normal but not snappy. If I apply very little brake the pedal takes about 3-4 seconds to return about 1" of travel. I am at a loss with no more stuff to replace. I need more ideas and help please!!!
Old 03-09-2014, 09:03 PM   #9 (permalink)
Ram Year: 1998
Engine: 5.2
Default
I have never had to dive into the brake system of my Ram this deep. Do we have a proportioning valve and if so could that be a potential culprit for this problem? Sorry bro, I am trying to think of possible solutions.
Old 03-09-2014, 09:22 PM   #10 (permalink)
Ram Year: truck
Engine: gas
Default
^^^ Yes we do have a proportioning valve on these trucks, we also have a piss poor ABS system as well. I would start by replacing all the soft lines and go from there.
Merc225hp is offline   Reply With Quote
Reply
Bookmarks
Tags
bad brakes, brake problems, no brakes, slow pedal return
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
brake pedal no return ice cold General Discussions 4 01-17-2014 12:41 AM
Free play in brake pedal bendirkss Tech Info 5 09-26-2013 08:28 AM
Clunk in brake pedal MayheM Tech Info 9 08-14-2013 10:38 PM
90 ram brake pedal stiff 90ram Engine & Performance 2 02-17-2013 05:33 PM
"CHIME" when brake pedal is depressed on 07 w/3.7 V6 eallanboggs Tech Info 6 08-09-2010 07:57 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
