Trans temp and pressure guages
01rammer1500
Im looking to install trans temp and pressure guages on my truck. Its a 2001 with the 46re trans. Anyone done it? Or have any idea what will work best
Sent from my LG-D850 using Tapatalk
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
An aftermarket tranny pan or remove yours and drill a hole on the side, just be careful alot of tranny fluid comes out
dapepper9
Iowa/Nebraska Border
5.9L V8
B&M makes a really nice pan for our trucks. I have one (that i still haven't gotten to put on yet). Also glowshift makes good guages (also have one that is not installed yet).
tommyboi87
houma louisiana
5.2 Magnum
You have a test port on the passenger side of the transmission. That's where I just hooked mine to. I have the temp gauge, but not a pressure gauge. Don't mind the 300 degrees readout. The truck wasn't started. All power and ground wires are run to the radio.
Sent from my SAMSUNG-SM-G925A using Tapatalk
dapepper9
5.9L V8
You wouldn't happen to have a picture of where the test port is would you? I got so much crap on there right now idk what's what
01rammer1500
What guage did you buy? Photos of the full install would be much appreciated!!!
tommyboi87
houma louisiana
5.2 Magnum
I can't find one right now, but I'll take one tomorrow. Can't really miss it though. Under the passenger side on the transmission, right above the pan, you'll see to small hex head bolts. One close to the dipstick, and one further behind. The second one is the test port. You'll need an extender to put a heat or pressure probe there because of moving parts. Glowshift makes them.
tommyboi87
houma louisiana
5.2 Magnum
I bought the glowshift 7 color changing temp gauge. Right under 60 bucks shipped. Took two days to get here from amazon. I didn't take pics, wish I would have. I'll get some pics of how everything is run tomorrow.
01rammer1500
Thank you. The only reason I'm wanting to run a pressure gauge, is because my truck keeps blowing cooler lines. Its at very random times. So I'm wanting to be able to watch both gauges to see what is going on when my lines are blowing.
dapepper9
5.9L V8
I wish i would have known this earlier lol. I could have wired up and installed my gauge until i get the new pan in them relocate it to the included port for the pan
tommyboi87
houma louisiana
5.2 Magnum
Sounds like what some people call the bladder in the radiator.. I don't know the actual term for it, but coolant and trans fluid could be mixing in your radiator causing pressure on the lines.
01rammer1500
It happens randomly. It did it like once a month when it was winter. 3 days ago it did it again. Which is the first time in 7 months. I ordered an aftermarket cooler to see if it will help. I might just run a pressure gauge to the line that's blowing, just to see if i can catch a sudden jump.
tommyboi87
houma louisiana
5.2 Magnum
Nah, you'd know if it were that. Might have trash in the lines. But I'm not a transmission expert lol
01rammer1500
Think an oil pressure gauge will work to get a pressure reading from the line?
