I'm driving a '99 Ram 1500 4x4, 5.9ci, 206k miles. Everything is stock. A few months ago the rear u-joint (rear drive shaft) came apart and the drive shaft fell out on the road. To say "fell out" may be a bit tame since it beat around under the truck until the front yoke slipped out -- a few seconds at 55mph.
Installed new joints and reinstalled the shaft, but had a terrible vibration so, thinking the shaft may have been bent in the process, I measured the runout (about .040") and counterbalanced with a couple of pipe straps. That helped quite a bit, so I elected to drive it. Now the vibration has returned (gotten worse) so thought I'd replace the driveshaft. Done -- with no improvement. I have rotated the shaft on the spline several times in small increments holing to hit a sweet spot for shaft balance with no joy. Still vibrates.
The vibration is definitely driveline related. Begins at about 45mph and the 4x4 shifter begins to vibrate. Not tires I don't think because there's no other vibration in the truck other than at the transfer case. The odd thing is that when traveling straight at 45 (with the vibration quite noticeable) I can engage the transfer case into 4H and the vibration essentially stops. Did I damage something in the transfer case when the driveshaft came out?
