Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Tech Info
Sponsored Ads
Register to remove these ads.
Tech Info
Transfercase help
This is a discussion on Transfercase help within the Tech Info forums, part of the 2nd Gen : 1994 - 2002 category!
Register to remove these ads. It's free! Ok I got the transfercase and its a 241 and I pulled mine ...
Reply
Old 01-07-2012, 09:50 PM   #11 (permalink)
Ram Year: 2001
Engine: 360
Default
Ok I got the transfercase and its a 241 and I pulled mine off and its a 231 every thing looks the same except the 241 is a little bigger and the front drive shaft out of the tcase is a spline and my 231 had a nut holding the companion flange on what to do to make it work
Sent from my ADR6300 using Tapatalk
gambler2jake is offline   Reply With Quote
Old 01-07-2012, 09:58 PM   #12 (permalink)
Badger's Avatar
Ram Year: 1996
Engine: 5.9L Magnum 360
Default
Go get the front drive shaft. Congrats on upgrading.
__________________
1. Debadged tailgate 2. Chrome wheel well trim 3. 285/75/16 Pro Comp All Terrain 4. Painted tail light covers 5. Tinted rear window 6. Factory style aluminum nerf bars. 7. Cobra CB with 4ft Barjan dual whips 8. Deer antler shifter 9. Rear coilover conversion 10. Stainless rocker trim 11. Shorty antenna 12. Custom light mount behind grille 13. Thrush Glasspack
Badger is offline   Reply With Quote
Old 01-08-2012, 09:52 AM   #13 (permalink)
Rogan68's Avatar
Ram Year: 2001
Engine: 5.9L CTD 24v 6 hole Bolt-action
Default
Agreed. The 231 has a 3-gear planetary section, and the 241 is a 6-gear unit.
The NV231 transfer case is used behind many V6 and V8 engines in pickups and sport utility vehicles.
The NV231HD, used in the 1994+ Ram with V6 and V8 engines, features larger bearings and a wider chain than the NV231. All versions of the 231 cases use three gears in the planetary reduction set.
The NV241 is essentially a NV231HD with six gears in the planetary set.
The NV241D is a heavier duty Dodge version of the 241, with a larger input shaft and larger bearings to withstand the torque of the V10 and diesel engines.
The NV241HD, an option on Ram 2500's and standard on Ram 3500's built after 1998, has a stronger case and wider drive chain to better withstand the shock of snow plow service, a PTO cover and drive gear, and an extra bearing to support the thrust to the main shaft created by a PTO adapter.
Except for dimensional differences and the PTO port on the NV241HD, all of the cases are almost identical in appearance. An identification tag is attached to the rear case of every transfer case. The tag provides the transfer case model number, assembly number, serial number, and low range ratio. The transfer case serial number also provides the date of build. For example, a serial number of 9-10-93 would represent September 10, 1993.
Code:
NV Gear Transfer Case Specifications
  	       NV231 NV231HD 	NV241 	NV241D 	NV241HD   NV271
Weight
(lb) 	          65 	72 	80 	?  	100 	  120
Input Torque
(Cont ft-lb)     730   730      1028 	1028 	1400 	NA
Input Torque
(Max ft-lb)      1,885   1,940  5,555 	5,555     5,555 7890
GVWR
(lb) 	         5,920   6,400 	8,800 	10,500 	11,000 	17,500
Fluid Cap
(pt) 	         2.5     2.5    4.7 	4.7 	6.5 	4.0
__________________
'01 QCSB 5.9L Cummins - 6speed, Edge Juice w/Attitude, BHAF, 5" Diamond Eye TBE
'96 SCLB 5.9L Cummins - #10, BHAF, 4" DP, 7" Miter Stack, Leveler, 4500, M275s, Jake
'03 QCSB 4.7 2WD - all original, 98k mi., dual exhaust - My late father's truck. RIP, pops! 4/11/36 - 3/26/11
Rogan68 is online now   Reply With Quote
Old 01-09-2012, 12:43 PM   #14 (permalink)
Ram Year: 2001
Engine: 360
Default
Any one know where I can find a splined slip yoke for the front drive shaft none of my junk yards have any
Old 01-10-2012, 01:42 PM   #15 (permalink)
Rogan68's Avatar
Ram Year: 2001
Default
Is it a 241LD or HD?
If the front output is a slip-style HD tcase, and you want to convert to flange style, you'll need to replace the 241HD output shaft HD# QU10200 ($60) and QK2006 flange kit ($289)
LD parts are shaft QU50505 ($130) and QK2006 flange kit ($289)
QUAD 4x4 Home Page - DODGE
that's where I get my NV4500/NV5600/231/241 parts from.
__________________
Old 01-13-2012, 10:53 AM   #16 (permalink)
Ram Year: 2001
Engine: 360
Default
I don't have that kinda money right now is there just a slip yoke I can buy for now that will get me by till spring when I can redo it
Old 01-13-2012, 11:50 AM   #17 (permalink)
Rogan68's Avatar
Ram Year: 2001
Default
If it's a CV flange front driveshaft, I doubt it.
I'd have to look, but I don't recall seeing a slip yoke tcase for a front driveshaft. All the ones I've seen, the driveshaft, itself, handles the compressions. do you have a pic of this? what year is it out of?
Only slip-yoke front tcase flanges I've seen are like old IHs or Broncos, etc.
__________________
Old 01-13-2012, 12:10 PM   #18 (permalink)
Ram Year: 2001
Engine: 360
Default
The t case is a 241d out of a 02 RAM not sure what make tho and all it has coming out the front is the spline I will see if I can get a pic of it
Old 01-13-2012, 01:00 PM   #19 (permalink)
Rogan68's Avatar
Ram Year: 2001
Default
Ok, it's an "LD" style of the 241 for Dodge; I didn't realize there was so much difference from it and the Jeep version. The Jeep 241D is a bolt-on for the front output shaft.
Is it a 32 spline? The Rubicon 241OR uses the slip-style, and is 32 spline.
__________________
Old 01-13-2012, 01:10 PM   #20 (permalink)
Ram Year: 2001
Engine: 360
Default
I think it was wrote on it 30 spline
Reply
Bookmarks
Tags
2nd gen ram transfer case, ram transfer case, swapping transfer case
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
