diehardchief
- Dec 16, 2015
- 3
- 0
- 2001
- 5.2L
Figured Id post this up to see what input the experienced Dodge guys have on my issue.
First off its a prob a stupid question but bear with me.
I did a transmission filter/gasket change on my 2001 Dodge Ram 2WD 5.2L Automatic, 14 bolt pan.
I purchased the Purolator/Proline Transmission Filter (PPL1262) from Pepboys.
Heres my question, does this filter have some kind of cork like material that plugs the filter hole? Im referring to the circular hole that faces upward on filter. Is something placed in here from factory to prevent dust or anything going into filter?
Also if there was something blocking that hole would I be able to add 6 qts of transmission fluid without it being obvious on dipstick? IE would fluid level be insanely high on stick because filter hole is blocked?
Im not noticing any difference in transmission shifts.
Fluid level checked after short drive and it is in range of normal level. added 6 qts if ATF+4 after filer change.
Any advice or help is greatly appreciated. It could just be me not remembering if that hole was plugged, Ive never bought transmission filters with that hole being plugged but that doesn't mean it isn't done.
