Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Tech Info
Sponsored Ads
Register to remove these ads.
Tech Info
Wheel bearings
This is a discussion on Wheel bearings within the Tech Info forums, part of the 2nd Gen : 1994 - 2002 category!
Register to remove these ads. It's free! I'm replacing the front rotors on my 95 ram 1500 2wd and was ...
Reply
Old 01-29-2012, 08:34 AM   #1 (permalink)
Ram Year: 1995
Engine: 5.2
Default Wheel bearings
I'm replacing the front rotors on my 95 ram 1500 2wd and was wondering if you need to replace the wheel bearings when doing this job.
rockercsx is offline   Reply With Quote
Old 01-29-2012, 08:53 AM   #2 (permalink)
Okiespaniel's Avatar
Ram Year: 2000
Engine: magnum, 5.9
Default
Are they the old style bearing/race combo or a sealed hub.
If they're the old style, inspect the races for heat discoloration and scratches or water erosion. The "cones" or rollers shold be be tight If the cage holding the rollers in place is sloppy, I'd replace. It is best to replace the cone and race at the same time, along with the seal.
Sedaled hubs...put the tire back on, grag the tire at top and bottom and wiggle it. If the hub has any play in it the hub assembly should be replaced.
__________________
Life is a Highway...I wanna drive it all night long...
Okiespaniel is offline   Reply With Quote
Old 01-29-2012, 03:02 PM   #3 (permalink)
txbass06's Avatar
2nd Gen / Site Mod
Ram Year: 1997
Engine: 5.9 Magnum
Default
Yours should be the old style with separate bearings and races. Most replacement rotors will already have new races pressed into them and the bearings shouldn't be more than a few bucks each, depending on the brand. I'd go ahead and replace them at that price. It's cheap insurance and could keep a failure form happening in the future
__________________
RamForum.com Moderator
Black Truck Club #21
Texas Truck Club #2
Mods: S&B Intake, Dynomax Bullet, Blacked Out Headlights, Grill and Bumpers, 6000k HID's, Bull Bar w/ Hella 500 Black Magics, Leveled, Blacked out M/T Classic II's wrapped in 315/75R16 Kumho AT's
Dodge Ram Forum | Ram Forum | Ram 1500 Forum | Dodge Truck Forum | Dodge Ram Parts | Dodge Ram Accessories | Dodge Ram Performance
txbass06 is offline   Reply With Quote
Old 01-29-2012, 03:20 PM   #4 (permalink)
Ram Year: 2000
Engine: magnum, 5.9
Default
When I started in the parts business many many years ago we learned never to trust the races stuck in drums and rotors. They are placed in there to affect accurate machining of the part and because of that thier heat treating quality is suspect. They were /are just a clamping surface.
Also, most cones take a set to the race (like gears and cam/lifter surfaces) when run, and while you can sometimes get away without changing them out, one failure can be pretty expensive and time consuming.
Bearing sets only cost a few dollars overall, and you can rent a remover /installer tool and return it.
__________________
Old 01-29-2012, 04:57 PM   #5 (permalink)
Ram Year: 1995
Engine: 5.2
Default
Thanks for your replies, looks like i'll replace the races and bearings. Need to do the ball joints too so i'll rent a press and get it all done.
Reply
Bookmarks
Tags
2nd gen wheel bearing, dodge ram wheel bearings
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
5th Wheel - what can I tow? steveclv General Discussions 10 11-19-2011 02:35 AM
Need wheel help codesman Exterior 5 11-13-2011 09:32 AM
4 Wheel Jamboree!!!! Bigtman07 The Lounge 18 05-22-2011 04:47 PM
wheel day.... jusjay727 Exterior 31 10-24-2010 11:50 AM
wheel bearings badfish888 General Discussions 2 08-12-2010 06:00 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
