reb4wd99
- Feb 24, 2014
- 11
- 5
- 2014
- 6.7 Cummings
Kind of new to the lifted world. Got a question for you. I bought a new 2014 ram 2500. The dealer put a 3" lift kit (kit unknown) and 35" tires on it. They did not replace the shocks, as it still has the factory shocks on it. The truck rides rough, as you would expect with any lifted truck with 35" tires on it, and has more than normal/expected vibrations on the interstate. I had tires re-balanced when I purchased and before i drove off the lot. My question is do you think the factory shocks are over extended to the point where they can no longer effectively dampen vibrations and do you think replacing with aftermarket shocks would help achieve a smoother ride? I'm not looking for a Cadillac ride. I knew what I was getting into prior to buying the truck, but was just wondering if you big **** mother ******* could recommend a set of good quality shocks that could help with the ride, if shocks would indeed help with the issue? If you don't think it is a shock problem, what other things could I check/replace to help? I will also be purchasing a dual steering stabilizer kit as well to help. Thanks for any input.
