Another DEF question.
Leebo
6.7 diesel
I bought a 2013 Ram Laramie longhorn 6.7 diesel dually used with 50332 miles. I love this truck. Since buying it ( about 2.5 months) I have put just over 3000 miles on it. I don't pull anything right now. The DEF gauge has not moved off full since the day I brought it home.
This cant be normal can it? Anyone have thoughts on this or am I just looking for trouble?
crash68
ACME product engineer
Administrator
3.0 EcoDiesel
The CTD doesn't use much DEF when not towing, your probably fine if you haven't thrown any codes. Normal DEF usage is about 1-2% of the amount of fuel burned.
The DEF tank sending unit isn't very linear either, the top and bottom of the tank moves slower than the middle. It's not a float either, uses an ultrasonic detection of the fluid level.
L
Leebo
6.7 diesel
Thanks
Thanks Crash. I think I will keep some DEF on hand just to be on the safe side.
I appreciate your time.
Leebo
VLG6963
