Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > General Discussions
General Discussions
First winter
This is a discussion on First winter within the General Discussions forums, part of the Dodge Ram Cummins Diesel Forum category!
Hi there, this will be my first winter with a Diesel and i have a few questions for people who ...
Like Tree3Likes
  • 1 Post By Dirka13
  • 1 Post By MADDOG
  • 1 Post By crash68
Reply
Old 12-15-2016, 12:32 AM   #1 (permalink)
Ram Year: 2016
Engine: Cummins 6.7
Default First winter
Hi there, this will be my first winter with a Diesel and i have a few questions for people who live in colder climates. I live in southern Ontario and I may not see extended cold days like Alberta we do however see a few days in the -30 degree Celsius. just today we hit -17 with the windchill. I have started using my block heater the other day and plugged it in for 3 hours before i had to leave for work, yet the instrument panel still said 0degress for my trans temp and the minimum of 40 for my coolant and 40 for oil when i started my truck. Am i plugging into the wrong plug? (near the tow hook on passenger side) also i just went to plug it in just a few minutes ago after my shift and stupid me forgot to unplug the extension cord before plugging into the block heater cord and a few sparks came off the connector, do you think i fried the block heater? and is there a way to check? its a 2016 3500. also is there any other advise anyone could share about winter climates for my diesel? like how low should my oil kpa be before i put the truck in gear or anything like that. thank you so much this forum is very helpful.
MarkV likes this.
Sponsored Ad
Register to remove this ad.
Dirka13 is offline   Reply With Quote
Old 12-15-2016, 04:20 AM   #2 (permalink)
crash68's Avatar
Ram Year: 2015
Engine: 3.0 EcoDiesel
Default
In those kind of cold temps, leave it plugged in when it's parked.
crash68 is offline   Reply With Quote
Old 12-15-2016, 12:30 PM   #3 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2014 Big Horn Crew
Engine: HEMI 6.4L
Default
Sparks won't be a problem, smoke will be a problem.
It won't heat much up in 3 hours. Plug it in the night before you go to bed for the next day's start up.
THETANK likes this.
__________________
MICHAEL
SUPER MODERATOR
2014 BIG HORN CC / 6.4L HEMI
AFE / ARMA COAT / BFG KO2 / DIABLOSPORT / HEMIFEVER
MAGNAFLOW / N-FAB / PIAA / PRO TECH / TUFF COUNTRY / WALKER EVANS RACING
MADDOG is offline   Reply With Quote
Old 12-15-2016, 05:35 PM   #4 (permalink)
CDN Ram's Avatar
Ram Year: 2014 Laramie
Engine: 6.7L CTD
Default
although I agree sparks aren't the problem smoke sure would be. but if you plug in the block heater when the engine is cold you should be able to hear peculating noise, kinda like a kettle when you first plug it in, that will tell you the block heater is working, apart from that you can multimeter it and look for continuity.
As for the length of time to plug in, on a gasser three hours is lots, on a diesel I still think 3 or 4 hours is enough, but it's a personal thing I guess.
Taken from another site "the block heater is 1500w or more, which is like running a hair dryer all the time, or 15 100w lightbulbs. Or 5 average home computers. 7 laptops. You get the idea."
Would you leave 15 lights on all night and not expect the hydro bill to climb?The longer you leave it on the higher the electric bill.
__________________
2014 RAM 3500 Laramie 4X4 Mega Cab 6.7 Cummins
CDN Ram is offline   Reply With Quote
Old 12-17-2016, 12:57 AM   #5 (permalink)
Ram Year: 2016
Engine: Cummins 6.7
Default
Hello again, was unable to post yesterday as the power went out. so i have a couple pics. the one shows how cold the readings are even after being plugged in all night, and the other two are the block heater plug after the sparks. im very new to this whole block heater thing as ive never used one. i mean the truck started without the use of the glow plugs when i used the key so does that mean the block heater did its job, it just doesnt show on the instrument panel right away? thanks again for all the help, its greatly appreciated.
Old 12-17-2016, 04:22 AM   #6 (permalink)
Ram Year: 2015
Engine: Diesel 6.7
Default
Your heater block seems to be working. The temp shows 40 C while the outside temp was at -8C.
Carlo
MyTruck is offline   Reply With Quote
Old 12-17-2016, 12:55 PM   #7 (permalink)
Ram Year: 2016
Engine: Cummins 6.7
Default
40 degrees is the lowest it will go that's why I'm a little iffy on it.
Old 12-18-2016, 03:22 AM   #8 (permalink)
Ram Year: 2015
Engine: Diesel 6.7
Default
Yes you are right 40 for celsius and 100 for fahrenheit. Another way telling if your block heater is working is:
In the morning start, check if the grid heater is taking a while before the light goes out. If it takes less than 5 seconds, then that means the coolant was warm enough for a start.
Carlo
Old 12-18-2016, 05:57 AM   #9 (permalink)
crash68's Avatar
Ram Year: 2015
Default
The OEM Cummins block heater is 750 watts.
crewchief likes this.
Old 12-18-2016, 04:26 PM   #10 (permalink)
Ram Year: 2016
Engine: Cummins 6.7
Default
thank you for the helpful info.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Winter Set up Solid State Lifted 2 06-27-2016 05:02 PM
Chrome + winter + salt = F winter!! RBR73 Exterior 24 02-14-2016 03:56 PM
Winter ZOMBIEKILLER Detailing 15 02-12-2015 04:23 PM
winter sig Badger Test 1 12-21-2011 10:49 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
