Led no drill hood mounts
BBRAM2500
stony plain Alberta
Last week i think i saw some one here looking for a way to attach led to the mirror or hood well i ordered these and thought i might share as a clean no drilling solution to mount leds they seem well built dont scratch the hood are made of 304 stainless and were 19.00 american to the door
stimpy433
IOWA
Got a link to where you bought them????
OnSale
5th Gen Crew
Philadelphia, Pa
Do you think there is enough room or enough of a gap to mount these little "brackets" at the front of the hood where it meets the grille? I think a lightbar would look better along there then along the bottom of the windshield.
Could you do me a yuuuuge favor and test it out on your truck and see if the hood can be closed with them at the front. Thanks man!!
Sent from my SM-J320P using Tapatalk
WillO
South Florida
I like these, but not sure if the glare you would get from having them mounted in that position. Look forward to seeing them installed and lit up!
OnSale
5th Gen Crew
Philadelphia, Pa
So i have a visor so i cant test but where hood meets the headlamps it will work
Cool thanks. For how cheap they are ill just pick up a pair and see if i can get something to work.
BBRAM2500
BBRAM2500
stony plain Alberta
So i threw it on quick tonight
stimpy433
IOWA
Any clearance problems opening your hood with them mounted???
stimpy433
IOWA
How tall are they measured from the top of the hood to the top of the LED light???
Power247
High Point, NC
6.4 HEMI
The look good mounted. When you get a chance I'd like to see some night shots from. The driver's seat with them on.
Greg
2012 | RAM 2500 | CCSB | Custom tuned by Double R Diesel
2016 | Heartland Pioneer | DS310
BBRAM2500
BBRAM2500
stony plain Alberta
Will do and ive now leaned them lower to the hood
BBRAM2500
BBRAM2500
stony plain Alberta
So took a while but here is a picture of the hood lights on at night
crazykid1994
Florida
Looks amazing. Not as much glare as I'd expect. Probably because they are off towards the side so much where the hood curves down so not as much hood to hit. Gets some nice distance on it
