Intercooler? Do have a turbo? The tow hooks should be bolted or in my case welded to a solid piece of steel that is bolted to the frame. You should not have a problem with air flow, there are a lot of guys running them down there without a hitch. There's a member on here selling some mounting brackets for that location.how did you all mount your LED light bars? diff. brackets? If mounted between tow hooks, will/ did it block the air flow to intercooler?
Pics to please.
thanks,
John
Could have.... That is a 20". A 25" would fit between the tow hooks but wasn't sure how I was going to mount the light when I bought it. Nobody makes a mount for a 25" bar so if my homemade mount didn't work out I would have been stuck. Fitting a 30" bar requires shaving the tow hooks or having the light sit outside the bumper. Neither was something i wanted to do. Now that I have the mount worked out I will consider replacing with a 25" if/when this one dies. But for now I am happy with my $50 mod.You probably could have gone wider huh?
Artic-rodz, where did you get the bar and brackets from
