jadocs
- Mar 23, 2014
- 689
- 140
- 2014
- 6.7
Hey all,
I've been doing a lot of searching and I can't quite locate the answer I'm looking for.
I'm thinking about replacing the transmission and both differential covers on my RAM. I can't find anything that states compatibility with my model year. It seems to be only up to 2013.
Anyway have you, or have you seen anything on the net in reference to a 2014+ install?
Also cannot locate an answer for the following;
- Will a front diff cover work? Apparently there is mention of clearance issues with steering/dampening components.
- Trans pan: what do I need to know about the internal filter and this trans pan? I found some old threads that talk about replacing the stock filter with something else so it is compatible with this pan? Why would you need to do that?
Thanks in advance.
Thanks in advance.
