sorry for dumb question, i'm a newbie, if u dont use the exhaust brake does the truck
The hippie
cummins
sorry for dumb question, i'm a newbie, if u dont use the exhaust brake does the truck consume the diesel exhaust fluid DEF at all? or at a slower rate? TRUCK is 2015 Ram 2500 diesel cummins.
markyfly
Toronto
The exhaust brake and the after treatment system are 2 completely separate things. The exhaust brake slows you down by using the compression of the engine.
The DEF is injected into the exhaust to break down the NOx emissions into nitrogen and oxygen
14hemiexpress
Texas
6.4l
What he said^^^ no dumb questions here! That's why we're all here is to ask questions and share knowledge.
AirborneRGR
You should ALWAYS use the exhaust brake to prevent carbon build up on the actuator in the turbo. It's a variable geometry turbo, over time carbon will build up and prevent it from sliding. Using the exhaust brake, engages the actuator when you let off the throttle, to slow the vehicle.
Long periods of idling are also bad for the turbo and DPF. Delete it.....
xrsman
Ontario
3.0 Ecodiesel
I have no input except for the fact that it'll save on brake wear :)
T
The hippie
cummins
Thanks for your reply. One last question, when i press on the switch of the exhaust brake, its 'icon' on the dashboard turns orange yellow & when you press once more it turns to green. What does the orange yellow and green represent? I assume that orange yellow means half the exhaust brake is engaged and greeen means full exhaust brake engaged?
loveracing1988
Clarkston, MI
Unless they changed something the Cummins has never used a variable vane turbo. It is a variable nozzle which doesn't coke up like the variable vane turbo's that GM and Ford use.
Since it is a 2015 truck there is no good reason to delete it, I'm sure most people like the whole not getting cancer thing.
NWRQC
They do and have choked up with soot if you don't use the exhaust brake. Soot prevents the collar from sliding.
I do have to agree about not needing to delete. Aftermarket tuning will do to a new emission intact truck what deleting did a few years ago. EFI-Live has opened a lot of doors.
