Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > P Pump
P Pump
1998 2500 5.9L, No Crank, No Start
This is a discussion on 1998 2500 5.9L, No Crank, No Start within the P Pump forums, part of the Dodge Ram Cummins Diesel Forum category!
So 1998 2500 with the 12 valve 5.9L Cummins. Yesterday as I got in I noticed the airbag warning and ...
Closed Thread
Old 04-08-2016, 11:13 PM   #1 (permalink)
Ram Year: 1998
Engine: 5.9 Cummins
Default 1998 2500 5.9L, No Crank, No Start
Yesterday as I got in I noticed the airbag warning and ABS lights were on as I started the motor. Thinking it odd, I shut down the motor and attempted restart hoping to clear the warning lights as I had never seen them on before. Then the engine failed to start. When the ignition key is turned from the on position to the start position there is a loud click heard from the left side of the engine compartment and the motor DOES NOT CRANK. The click will only be heard once and it takes shutting the ignition switch off and then attempting to restart to hear it again. In addition my blower switch does not work.
Things I have done so far.
1. Cleaned all the battery connections and recharged the batteries.
2. Jumped the starter and the starter does crank. With the ignition switch in the on position the engine will not start when jumped.
3. Swaped the trailer relay and starter relay. This produced one engine start ONLY and now we are back to the original symptoms...
4. Replaced all the Multi use relays with new. Still same symptoms.
Ok where do I go from here?
Peter L
Sponsored Ad
Register to remove this ad.
Peter L is offline
Old 04-09-2016, 01:01 AM   #2 (permalink)
MagSport's Avatar
Ram Year: 1999
Engine: 5.9
Default
Two things come to mind: neutral safety switch and/or bad ignition switch. The only time my air bag and abs lights come on at the same time like your describing is when the truck is on/running but the switch is off (I have remote start). That kind of leads me to believe that perhaps some functions of the switch are working but others (maybe the starting function) are not.
The neutral safety switch won't allow you to start if you're not in park or Nuetral. Have you tried to start it in Nuetral?
__________________
99 Ram 1500 Sport
MagSport is offline
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
1998 2500 5.9L No Crank No Start Peter L Engine & Performance 4 04-09-2016 01:06 AM
Will crank,won't start EllieMaeMassey Engine & Performance 7 01-19-2016 11:12 AM
No Crank No start PCT Engine & Performance 2 06-12-2015 11:48 PM
Help with a no crank/no start on my imported 2500. ImportDodge Tech Info 3 04-03-2015 08:33 AM
2014 2500 6.4 crank/no start and other electrical tommy_harrell Engine & Performance 8 06-12-2014 11:44 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
