Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > P Pump
P Pump
1998 3500 problems help!
This is a discussion on 1998 3500 problems help! within the P Pump forums, part of the Dodge Ram Cummins Diesel Forum category!
Whe i arrived home tonight i smelled burning electrical i realized it was my truck i got it parked and ...
Reply
Old 08-13-2012, 07:16 PM   #1 (permalink)
fla crkr 1 ton's Avatar
Ram Year: 2001
Engine: 5.9 [360]
Default 1998 3500 problems help!
Whe i arrived home tonight i smelled burning electrical i realized it was my truck i got it parked and turned off the key but the engine kept running [5.9 diesel/auto] i opened the hood the smoke was coming from the fusebox in the ebgine bay i ran to the garage to get tools to remove the battery cables when i got back the engine had shutoff i removed the cables and accessed the damage. I found a ground wire that had been dangling in the area of the air heat relays [two small coil looking things under the drivers battery] it had touched one of the positive posts of those and shorted out melting off the insulation and causing the smoke i don't know what else was melted have not tore into it. Once i found the culprate it was removed and i hooked up one battery to test and see what did not work lights,signals,blower motor ect works. I hooked up both batterys and went for a start she fired up and died right away tried a second time same result but i noticed that i had no wait to start light so i turned the key to on and everything else came on [self test] as advertised but no wait to start light this is where i stopped and disconnected the batterys so no more damage is done and i'm unsure of what to do next. I'm thinking that i may have fried sonething in the fuel shutoff either the relays or the shutoff solenoid but i'm not a diesel mechanic i'm an old school hot rod guy. Any help would be appreciated.
Sponsored Ad
Register to remove this ad.
__________________
Redneck engineer'in beat ta fit paint ta match!!
1998 ram 3500 cummins dually
1966 plymouth barracuda 273 cid auto
2011 mustang v6 305 hp 6 speed manual
2006 volkswagon jetta 2.5
USAF Aircraft Mechanic 1979-1989
fla crkr 1 ton is offline   Reply With Quote
Old 08-14-2012, 10:00 AM   #2 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Engine: P-Star Jeep Wrangler
Default
Ugh , electrical .. good luck bud
ramhunter9 is offline   Reply With Quote
Old 08-14-2012, 12:52 PM   #3 (permalink)
USMC1188's Avatar
Ram Year: 2007
Engine: 5.9 Cummins
Default
What he said...
Is there any CELs?
USMC1188 is offline   Reply With Quote
Reply
Tags
cummins electrical burnt, dodge diesel electrical
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
1998 dodge ram 1500- advice needed please! JON General Discussion 22 02-16-2012 11:10 PM
OBDII Error Code List For 1998.5 to 2002 Dodge Cummins Mopar1973Man VP44 Pump 1 12-11-2011 11:02 PM
1998 2500 RAM Seat Belts will not extend i65462 Interior 5 10-07-2011 12:29 PM
My 1998 3500 fla crkr 1 ton Member Trucks 8 11-16-2010 12:07 PM
1998 Dodge Ram SS/T Photoshoot TenneSS/T Member Trucks 14 08-09-2010 07:46 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
