P Pump CTD shaking/vibrating... DV's?
This is a discussion on CTD shaking/vibrating... DV's? within the P Pump forums, part of the Dodge Ram Cummins Diesel Forum category! Register to remove these ads. It's free!
I don't know how many of you guys know 12V's but I have ...
01-25-2012, 03:51 PM
#1 (permalink)
Ram Year: 1994
Engine: 5.9L Cummins
I don't know how many of you guys know 12V's but I have a 94.... The truck in my sig... When i bought the truck I noticed that the truck would start shaking or vibrating heavily in 5th gear when i get down around 40 MPH. I figured it was just because it was lugging it slightly. When i pushed into the pedal a little bit more it would clear up and power through it. I recently put 75 HP injectors in the truck from DDP and it has gotten a little worse. it will do it even at 45 MPH and when its cold even at 50 MPH, but it doesn't only happen in 5th gear now either. In 4th you can sometimes feel it but not as severe. It also seems to cackle a lot in the lower RPM range from around 1000 to 1400 but i think the cackle is just because of the exhaust that I am running... I remember hearing somewhere that Delivery Valves helps take away chatter (shaking/vibration?) with bigger injectors and didn't know if this was the same problem that they were talking about because it happened BEFORE i had my injectors too... it makes the truck more of a nuisance to drive, especially when the truck is colder. Any personal experience or knowledge is greatly appreciated!
Thanks
__________________
'94 2500 Cummins! NV4500 5spd, 3.55's DDP STAGE 2 75HP INJECTORS Fuel Plate and silencer ring gone with starwheel cranked and 18* of timing.. homemade 6" stack Guages(boost pyro and trans temp)! More to come....
01-25-2012, 09:37 PM
#2 (permalink)
Administrator / Owner
Ram Year: 1994
Engine: 7.5L
Struggling for fuel , you need a lift pump . Bigger injectors are going to make it worse ... If not kill the stocker . Sounds like the stocker was going south anyway .
I think I told you this at one point
Now this is just a guess from riding in your truck . Putter putter sputter sputter ..I NEED FUEL
__________________
RamForum.com Administrator/Owner/Vendor
Click the link for info
DB Truck Customs Facebook Page (Click Here)
dbtruckcustoms@gmail.com FOR ALL YOUR PARTS NEEDS or installs email/PM me for a price quote. If you want it chances are I can get it at a very good price ! Web Sight Coming Soon !!
01-26-2012, 10:50 AM
#3 (permalink)
Cummins Diesel Section Mod
Ram Year: 1996, 2002
Engine: 1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Check your fuel pressure... P7100 pumps are known for having weak overflow valves and losing fuel pressure...
Mopar1973Man's Dodge Cummins Articles - P7100 Injection Pump - Fuel Pressure
Also remember stock lift pumps are not efficent pumps for high performance then tend to come up short at high RPM's...
Technical Article Number One- The Cummins Lift Pump
__________________
Michael Nelson - RamForum.com Cummins Moderator 2002 Dodge Ram 2500 Cummins - Mod List ~+~ Pulling 2000 Jayco Eagle 296 FBS ~+~ 1996 Dodge Ram 1500 5.9L V8 - Mod List
01-26-2012, 03:09 PM
#4 (permalink)
Ram Year: 1994
Engine: 7.5L
What I said but in a more technical term ^
__________________
01-26-2012, 03:29 PM
#5 (permalink)
Ram Year: 1994
Then wouldnt it get worse in the higher RPM range instead of clearing up? that doesnt make sense...
__________________
01-26-2012, 04:10 PM
#6 (permalink)
Ram Year: 1994
Engine: 7.5L
With a load there is more need for fuel .
Your truck NEEDS more fuel in lower gears than top end . Taking off from a dead stop requires more fuel as the truck / motor needs to get going . At top end it already has the mass moving so less fuel is needed .
__________________
01-26-2012, 04:17 PM
#7 (permalink)
Ram Year: 2001
Engine: 5.9L CTD 24v 6 hole Bolt-action
does it smoke when you're experiencing this issue? If so, is it black or white/gray smoke?
__________________
'01 QCSB 5.9L Cummins - 6speed, Edge Juice w/Attitude, BHAF, 5" Diamond Eye TBE
'96 SCLB 5.9L Cummins - #10, BHAF, 4" DP, 7" Miter Stack, Leveler, 4500, M275s, Jake
'03 QCSB 4.7 2WD - all original, 98k mi., dual exhaust - My late father's truck. RIP, pops! 4/11/36 - 3/26/11
01-26-2012, 04:23 PM
#8 (permalink)
Ram Year: 1994
Engine: 7.5L
Greyish last time I seen it
__________________
01-26-2012, 04:26 PM
#9 (permalink)
Ram Year: 2001
That's definitely a fuel starvation then. Mine smoked gray when the lift pump was going out, and stuttered like hell.
per Tapatalk on my EVO
__________________
01-26-2012, 04:27 PM
#10 (permalink)
Ram Year: 2001
Both my 12 and 24 valves did
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
