Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > P Pump
P Pump
CTD shaking/vibrating... DV's?
This is a discussion on CTD shaking/vibrating... DV's? within the P Pump forums, part of the Dodge Ram Cummins Diesel Forum category!
I don't know how many of you guys know 12V's but I have a 94.... The truck in my sig... ...
Reply
Old 01-25-2012, 04:51 PM   #1 (permalink)
Montgomery Farms's Avatar
Ram Year: 1994
Engine: 5.9L Cummins
Default CTD shaking/vibrating... DV's?
I don't know how many of you guys know 12V's but I have a 94.... The truck in my sig... When i bought the truck I noticed that the truck would start shaking or vibrating heavily in 5th gear when i get down around 40 MPH. I figured it was just because it was lugging it slightly. When i pushed into the pedal a little bit more it would clear up and power through it. I recently put 75 HP injectors in the truck from DDP and it has gotten a little worse. it will do it even at 45 MPH and when its cold even at 50 MPH, but it doesn't only happen in 5th gear now either. In 4th you can sometimes feel it but not as severe. It also seems to cackle a lot in the lower RPM range from around 1000 to 1400 but i think the cackle is just because of the exhaust that I am running... I remember hearing somewhere that Delivery Valves helps take away chatter (shaking/vibration?) with bigger injectors and didn't know if this was the same problem that they were talking about because it happened BEFORE i had my injectors too... it makes the truck more of a nuisance to drive, especially when the truck is colder. Any personal experience or knowledge is greatly appreciated!
Thanks
Sponsored Ad
Register to remove this ad.
__________________
'94 2500 Cummins! NV4500 5spd, 3.55's DDP STAGE 2 75HP INJECTORS Fuel Plate and silencer ring gone with starwheel cranked and 18* of timing.. homemade 6" stack Guages(boost pyro and trans temp)! More to come....
Montgomery Farms is offline   Reply With Quote
Old 01-25-2012, 10:37 PM   #2 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Engine: P-Star Jeep Wrangler
Default
Struggling for fuel , you need a lift pump . Bigger injectors are going to make it worse ... If not kill the stocker . Sounds like the stocker was going south anyway .
I think I told you this at one point
Now this is just a guess from riding in your truck . Putter putter sputter sputter ..I NEED FUEL
ramhunter9 is offline   Reply With Quote
Old 01-26-2012, 11:50 AM   #3 (permalink)
Mopar1973Man's Avatar
Ram Year: 1996, 2002
Engine: 1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Default
Check your fuel pressure... P7100 pumps are known for having weak overflow valves and losing fuel pressure...
Mopar1973Man's Dodge Cummins Articles - P7100 Injection Pump - Fuel Pressure
Also remember stock lift pumps are not efficent pumps for high performance then tend to come up short at high RPM's...
Technical Article Number One- The Cummins Lift Pump
__________________
2002 Dodge Ram 2500 (Cummins Diesel) -=- 1996 Dodge Ram 1500 (5.9L Magnum)
Mopar1973Man is offline   Reply With Quote
Old 01-26-2012, 04:09 PM   #4 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Default
What I said but in a more technical term ^
Old 01-26-2012, 04:29 PM   #5 (permalink)
Ram Year: 1994
Default
Then wouldnt it get worse in the higher RPM range instead of clearing up? that doesnt make sense...
__________________
Old 01-26-2012, 05:10 PM   #6 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Default
With a load there is more need for fuel .
Your truck NEEDS more fuel in lower gears than top end . Taking off from a dead stop requires more fuel as the truck / motor needs to get going . At top end it already has the mass moving so less fuel is needed .
Old 01-26-2012, 05:17 PM   #7 (permalink)
Rogan68's Avatar
Ram Year: 2001
Engine: 5.9L CTD 24v 6 hole Bolt-action
Default
does it smoke when you're experiencing this issue? If so, is it black or white/gray smoke?
__________________
'97 ECLB DRW 5.9L Cummins - #0, BHAF, 4" Diamond Eye TBE - Built 47RE
'01 QCSB 5.9L Cummins - 6speed, Edge Juice w/Attitude, BHAF, 5" Diamond Eye TBE
'96 SCLB 5.9L Cummins - #10, BHAF, 4" DP, 7" Miter Stack, Leveler, 4500, M275s, Jake
'03 QCSB 4.7 2WD - all original, 98k mi., dual exhaust - My late father's truck. RIP, pops! 4/11/36 - 3/26/11
Rogan68 is offline   Reply With Quote
Old 01-26-2012, 05:23 PM   #8 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Default
Greyish last time I seen it
Old 01-26-2012, 05:26 PM   #9 (permalink)
Rogan68's Avatar
Ram Year: 2001
Default
That's definitely a fuel starvation then. Mine smoked gray when the lift pump was going out, and stuttered like hell.
per Tapatalk on my EVO
__________________
Old 01-26-2012, 05:27 PM   #10 (permalink)
Rogan68's Avatar
Ram Year: 2001
Default
Both my 12 and 24 valves did
__________________
Reply
Bookmarks
Tags
ctd fuel issues, ctd needs lift pump, new pump for ctd
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Shaking when braking.. please help! Tripp12345 Tech Info 19 07-24-2012 12:36 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
