Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > P Pump
P Pump
fuel leak no start
This is a discussion on fuel leak no start within the P Pump forums, part of the Dodge Ram Cummins Diesel Forum category!
Can a fuel leak where the line from the lift pump connects to the top of the fuel filter/ water ...
Like Tree7Likes
Reply
Old 11-08-2016, 11:26 PM   #1 (permalink)
Ram Year: 1996
Engine: Cummins 5.9
Default fuel leak no start
Can a fuel leak where the line from the lift pump connects to the top of the fuel filter/ water separator cause the truck to not start? The filter is definitely getting fuel as it is over flowing but I try to bleed the injectors and no fuel. Could air getting onto the system cause this?
Sponsored Ad
Register to remove this ad.
12vcummins59 is offline   Reply With Quote
Old 11-09-2016, 06:50 AM   #2 (permalink)
BrianandChrissy's Avatar
Ram Year: 2016 big horn crew cab
Engine: 5.7 hemi
Default
You ran the system dry bud
sent from galaxy S7 edge using tapatalk
BrianandChrissy is offline   Reply With Quote
Old 11-09-2016, 09:28 AM   #3 (permalink)
Ram Year: 1996
Engine: Cummins 5.9
Default
Should I be able to fix the leak and bleed the injectors and get it running?
Old 11-09-2016, 11:44 AM   #4 (permalink)
Engine: 5.7 hemi
Default
Cant bleed em. Gotta pressurize the whole system again
Old 11-09-2016, 11:51 AM   #5 (permalink)
Ram Year: 2012
Engine: 5.7 Hemi
Default
Bleeding the lines on a p pump won't do any good. It's only the vp pump on the 24 valves that requires you to bleed the air out. That mechanical lift pump has to have backside pressure to be able to push the fuel up to the injectors. Cracking the lines at the injector actually allows air back into the system on the back side and will keep the fuel from ever reaching the injectors. On the manual lift pump down on the side of the driver side of the motor there is a lever you can pump to re prime the system. It's gonna take a lot of pumps but it works. Or you can just keep cranking till it fires up. Or if you have a manual trans have someone drag you around in 3rd or 4th gear until it starts up.
vgoodson91 is offline   Reply With Quote
Old 11-09-2016, 07:39 PM   #6 (permalink)
Ram Year: 1996
Engine: Cummins 5.9
Default
So fix the leak and prime the hell out of it and she should start?
Old 11-09-2016, 07:43 PM   #7 (permalink)
Ram Year: 2012
Engine: 5.7 Hemi
Default
Yes sir. The priming is the sucky part. That's where a manual tranny makes all the difference. Or hook a battery charger up and just crank on it for 10 seconds or so at a time until it fires. Every time the crank rotates it pumps the pump essentially doing the same thing as you pumping the prime lever
Old 11-09-2016, 08:36 PM   #8 (permalink)
Ram Year: 1996
Engine: Cummins 5.9
Default
Thank you it is a manual so that'll help
BrianandChrissy likes this.
Old 11-09-2016, 08:58 PM   #9 (permalink)
Ram Year: 2012
Engine: 5.7 Hemi
Default
No problem. Let us know how it goes
Old 11-10-2016, 07:25 AM   #10 (permalink)
Engine: 5.7 hemi
Default
This is exactly why i love this forum. Great minds coming together to help one another. Now if only the president, congress, the house and the Senate could follow suit... this country could truly be great again!!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
I need severe help please! No fuel = no start = no fun Puckett1414 General Discussion 1 03-11-2016 04:31 PM
remote start with low fuel cc rider Audio & Electronics 37 04-06-2015 05:41 PM
NO Spark/Fuel/EFI - NO START 98 5.9 4x4 carcollector Engine & Performance 14 03-12-2014 11:26 PM
small fuel leak at fuel tank RAtmosphere 5.9 Common Rail 1 02-05-2014 05:22 PM
Fuel leak from hell cmerritt84 General Discussions 27 08-10-2011 09:46 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
