Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > P Pump
P Pump
need help on 1994 cummins
This is a discussion on need help on 1994 cummins within the P Pump forums, part of the Dodge Ram Cummins Diesel Forum category!
ok my friends 1994 dodge ram 2500 cummins has a automatic tranny and all the gears are perfectly fine has ...
Reply
Old 10-29-2011, 12:12 AM   #1 (permalink)
jbmobbs's Avatar
Ram Year: 1996
Engine: 5.9 360
Send a message via AIM to jbmobbs
Default need help on 1994 cummins
ok my friends 1994 dodge ram 2500 cummins has a automatic tranny and all the gears are perfectly fine has great pullin power but reverse went out could it be a sensor or vac leak or somethin like that?
Sponsored Ad
Register to remove this ad.
__________________
96 ram 1500 ex-cab long bed 4x4. 5.9 nv4500 5 speed fully loaded
97 ram 1500 regular cab short bed 2wd. 3.9 42rh automatic basic
jbmobbs is offline   Reply With Quote
Old 10-29-2011, 12:13 PM   #2 (permalink)
jbmobbs's Avatar
Ram Year: 1996
Engine: 5.9 360
Default
bump..
__________________
Old 10-29-2011, 12:15 PM   #3 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Engine: P-Star Jeep Wrangler
Default
Would best soot you to post in the correct section rather than posting a bump
I will move this to the CTD section .
ramhunter9 is offline   Reply With Quote
Old 10-29-2011, 12:18 PM   #4 (permalink)
jbmobbs's Avatar
Ram Year: 1996
Engine: 5.9 360
Default
i didnt know......its a transmission problem i didnt think it matterd so i posted it engine and tranny.....thanks for moven it to the proper section
__________________
Old 10-29-2011, 01:09 PM   #5 (permalink)
Badger's Avatar
Ram Year: 2004
Engine: 5.7 Hemi
Default
Is it throwing a code? If not top it off with fluid. If that doesn't help tranny is shot.
__________________
Badger is offline   Reply With Quote
Old 12-09-2011, 10:09 AM   #6 (permalink)
Rogan68's Avatar
Ram Year: 2001
Engine: 5.9L CTD 24v 6 hole Bolt-action
Default
94 has the 47RH trans (no electrics), as far as I remember. Only the TPS and PCM control fluid pressure. The TV cable can be adjusted a little to increase the internal fluid pressure, making more positive shifts, or vice verse.
no reverse could be a couple of things.
check the obvious, like fluid level. I know with the 44RE (Jeep) sometimes the front pump will suck air past the gasket, and not engage reverse (due to a fluid pressure drop. Overfilling by a quart would 'band-aid' the issue.
If the OD snap ring breaks, you'll lose OD and reverse.
Valve body loose will cause fluid pressure drop, and major slipping.
Band Adjustments
Pulling it in manual 1 on decel, look for engine braking. If either the low/reverse band is out or the direct clutches in the OD are messed up, you'll have no engine braking in manual 1. They should both not allow you to have any engine braking. If you have drive and OD then the front clutch appears to be working.
__________________
'97 ECLB DRW 5.9L Cummins - #0, BHAF, 4" Diamond Eye TBE - Built 47RE
'01 QCSB 5.9L Cummins - 6speed, Edge Juice w/Attitude, BHAF, 5" Diamond Eye TBE
'96 SCLB 5.9L Cummins - #10, BHAF, 4" DP, 7" Miter Stack, Leveler, 4500, M275s, Jake
'03 QCSB 4.7 2WD - all original, 98k mi., dual exhaust - My late father's truck. RIP, pops! 4/11/36 - 3/26/11
Rogan68 is offline   Reply With Quote
Reply
Bookmarks
Tags
dodge ram trans, ram trans issues, trans wont go in reverse
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
5.9 Cummins Exhaust ramthis9501 Xtreme Diesel Performance 1 10-26-2011 09:17 AM
Likes about your cummins bootsdodgejn General Discussions 15 08-23-2011 10:49 AM
1994-2001 Dodge Ram S&B Cold Air Intake RamSport97 For Sale 9 04-11-2011 01:59 AM
94 cummins WANTSOME bootsdodgejn Member Trucks 9 04-05-2011 03:35 PM
98 cummins 12 valve needs help fla crkr 1 ton Engine & Performance 0 03-19-2011 05:30 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
