Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > VP44 Pump
VP44 Pump
Injectors ? Easy job or not
This is a discussion on Injectors ? Easy job or not within the VP44 Pump forums, part of the Dodge Ram Cummins Diesel Forum category!
LOL , it is kinda I am going to do it , just worried about taking the fuel rails off ...
Reply
Old 09-27-2011, 05:53 PM   #11 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Engine: P-Star Jeep Wrangler
Default
LOL , it is kinda
I am going to do it , just worried about taking the fuel rails off and getting it all lined up with no leaks .
Sponsored Ad
Register to remove this ad.
ramhunter9 is offline   Reply With Quote
Old 09-27-2011, 08:32 PM   #12 (permalink)
Mopar1973Man's Avatar
Ram Year: 1996, 2002
Engine: 1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Default
The whole trick is keeping everything clean and sealing problems should occur. So get a can of engine degreaser and wash the engine down good and trhen get working after it dries.
__________________
2002 Dodge Ram 2500 (Cummins Diesel) -=- 1996 Dodge Ram 1500 (5.9L Magnum)
Mopar1973Man is offline   Reply With Quote
Old 09-28-2011, 10:04 AM   #13 (permalink)
KGBIGCOUNTRY's Avatar
Ram Year: 2004 RCSB/2005 QCSB
Engine: 5.7 / 5.7
Default
How are the Ctds primed stock? With an aftermarket lift pump that would do the priming to get the injectors and pump fed but how it it done stock on these trucks? Also would he have to crack the lines to burp out the air or is that not serious enough of an issue to be done? when I have done injectors on equipment I know I have had to crack the main line for the pump then the feed lines for the injectors also.
__________________
[CENTER]
Got Lope? WANNA GO FAST?
Hit us up at Moe's Performance for all your needs
http://www.moes-performance.com/
KGBIGCOUNTRY is offline   Reply With Quote
Old 09-28-2011, 10:33 AM   #14 (permalink)
Default
Typically you crack 1,3,4 to bleed the lines out. Tighten them down and fire it up.
__________________
Old 10-22-2011, 01:50 AM   #15 (permalink)
dripley's Avatar
Ram Year: 2002 2500 ho 6 speed 4X4
Engine: 5.9 24v cummins
Default
wel dave i forgot you had this page. i just changed my injectors out last weekend and you are chicken chit if you dont do it your self. it is quite easy. you dont need a spark plug wrench they just pop out. i was surprised at how easy it was. you get her opened up and do #! and just repeat. mike has a good point on the cleaning though. i sprayed my down pretty heavy before i took a bolt out of anything.
__________________
02 ctd 6 speed, adII165, rv 275's banks stinger plus, banks e brake, bhaf, 4" ex turbo back
dripley is offline   Reply With Quote
Old 02-09-2013, 02:43 PM   #16 (permalink)
CumminsCrazed's Avatar
Ram Year: 2001
Engine: 5.9 Cummins 24v
Send a message via AIM to CumminsCrazed Send a message via MSN to CumminsCrazed Send a message via Yahoo to CumminsCrazed Send a message via Skype™ to CumminsCrazed
Default
obviously hes already done it as truck is sold but yeah, take VC off, take lines and X tubes out, use valve cover bolt to pop old injectors out, use same bolt to pop new in...i did all 6 of mine is about 45min to an hour. Hardest part was # 6 line, tube and injector popping back in.
__________________
Silencer ring MIA, FASS 150/95 GPH, Boost Elbow, Edge Comp, AutoMeter Boost Pyro and Fuel Pressure gauges, LBDP Budget 5" Turbo Back Exhaust w/ 6" Flo_Pro tip, Amsoil Nanofiber 4510 Air intake filter, 20% Tint, B&M Racing T handle shift knob
CumminsCrazed is offline   Reply With Quote
Reply
Bookmarks
Tags
changing ctd injectors, ctd injectors
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
easy riding lift kit jbaronne Lifted 17 09-18-2011 01:40 PM
Here Goes, Be Easy On Me CAROLINA BAREFOOT Lifted 10 03-14-2011 04:40 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
