Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > VP44 Pump
VP44 Pump
Using 2 Cycle Oil in Diesel Fuel
This is a discussion on Using 2 Cycle Oil in Diesel Fuel within the VP44 Pump forums, part of the Dodge Ram Cummins Diesel Forum category!
Agreed but if ya got it use it. Thats my thought....
Reply
Old 08-28-2011, 04:30 PM   #11 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Engine: P-Star Jeep Wrangler
Default
Sponsored Ad
Register to remove this ad.
ramhunter9 is offline   Reply With Quote
Old 08-28-2011, 05:04 PM   #12 (permalink)
Mopar1973Man's Avatar
Ram Year: 1996, 2002
Engine: 1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Default
Ok... Use if for what?
Keeping injectors clean? If so then you might be mildly surprised about the filter in the connector tube called a edge filter.. But that what a fuel filter is for keep debris out of the injectors.
Quoted From Dodge's Factory Service Manual (2nd Gen VP44 and 3rd Gen CR)
Each fuel injector connector tube contains an edge filter (Fig. 13) that breaks up small contaminants that enter the injector. The edge filter uses the injectors pulsating high-pressure to break up most particles so they are small enough to pass through the injector.
So if its carbon build up you using the additive for you also be surprised you can soak it in any injector cleaner you wish and it will not remove anything. What cleans a injector nozzle its reaching 1,000*F EGT's and holding for several miles. Carbon burns at 1,000*F.
So if its catane booster you already know that higher the cetane lower the BTU content. Might be a consideration for winter time start ups but that about all.
If it lubricity... Well like you are finding out there isn't any major lubricant found in the MSDS sheets... As for AMSOil Diesel Con. it scored a 488 HFRR in the HFRR testing passing grade but low. And Bosch considers 450 HFRR border line...
Something to think about...
__________________
2002 Dodge Ram 2500 (Cummins Diesel) -=- 1996 Dodge Ram 1500 (5.9L Magnum)
Mopar1973Man is offline   Reply With Quote
Old 08-28-2011, 05:51 PM   #13 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Default
Dam you lol. I have 7 bottles. And the data shows the 2 stroke is better.
Old 08-28-2011, 05:54 PM   #14 (permalink)
MarbleCrusher's Avatar
Ram Year: 2002
Engine: VP Cummins
Default
Wow 7 bottles! Im sure that wasnt cheap either. Go grab some supertech and be safe happy and save on your wallet in the future.
-Jordan-
__________________
-02 Dodge 2500 cummins 4x4 6spd. Quad XZT+, Volant CAI, road armor w/ lonestar guard line-x'd, Fass 95 , 3in lvl kit, bilsteins.
-68 F-100, grandad bought it new gave it to me when i was 16 been restoring bak to factory ever since.
MarbleCrusher is offline   Reply With Quote
Old 08-28-2011, 05:56 PM   #15 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Default
Want some ? Lol
Old 08-28-2011, 09:22 PM   #16 (permalink)
dripley's Avatar
Ram Year: 2002 2500 ho 6 speed 4X4
Engine: 5.9 24v cummins
Default
I have been runnin it since installed my new vp about 15k ago. it even quiets the engine a little. every time i tow my rv i make sure i get the egt up above 1000 and hold it for a while to keep the injectors clean.
dripley is offline   Reply With Quote
Old 09-24-2016, 11:26 AM   #17 (permalink)
Ram Year: 2007.5
Engine: Cummins 6.7
Default 2007.5 dodge cummins
I just bought a 2007.5 dodge cummins and it has 100horse injectors. Should I or shouldn't I run 2 stroke oil in it?
MillsE45 is offline   Reply With Quote
Old 09-24-2016, 11:24 PM   #18 (permalink)
Jimmy68's Avatar
Ram Year: 2001
Engine: 5.2L Magnum
Default
Read first post again.
How much 2 cycle oil to use?
128:1 Ratio is fine for 12V and 24V Cummins trucks. On CR engines up to 07 you want to use 200:1 ratio. Beyond 07 don't use 2 cycle oil...
__________________
I've done more stupid sh#t as an adult than I ever did as a kid.
Trudeau & the NDP.
daylight savings. Leave the clocks alone.
NO TO BILL 6.
Jimmy68 is offline   Reply With Quote
Reply
Tags
2 cycle oil, diesel, fuel additives, hfrr
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2nd gen gasser to diesel Luke(MI) General Discussions 4 06-27-2011 04:31 PM
Motor cycle show pictures The Assassin Photos & Videos 6 02-11-2011 11:16 PM
Diesel Swap xxxotiknightz Engine & Performance 3 02-11-2011 10:51 PM
Diesel Programmer AWE Daniel eBay & Craiglist Listings 0 12-03-2010 11:15 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
