This is from Autogeek:
Nanoskin Autoscrub Towel – Fine Grade
Better known as the “clay towel”
The Nanoskin Autoscrub Towel replaces the traditional clay bar by providing a more efficient, cost effective way of removing above-surface bonded contaminants from your vehicle’s finish. Manufactured with an advanced rubber polymer coating on one side, the Nanoskin Autoscrub Towel makes achieving smooth, contaminant-free paint easier than ever. Remove paint over spray, bugs, tar, rail dust and industrial fall out with virtually no effort.
The Nanoskin Autoscrub Towel arguably makes the traditional clay bar obsolete. A traditional clay bar is only good for 5 to 10 cars. The Nanoskin Autoscrub Towel, thanks to its unique construction and advanced rubber polymer face, can be used up to 80 times! If you’re a professional detailer or car care enthusiast, the Nanoskin Autoscrub Towel is one of the best investments you can make!
It’s imperative that you remove above-surface contaminants before you polish or wax. Above-surface contaminants include paint overspray, bugs, tar, rail dust, and industrial fall out. By removing said contaminants, you create a smooth foundation that will allow a wax, sealant or coating to form a much greater bond. The cleaner the surface, the longer your wax, sealant or coating will last. The Nanoskin Autoscrub Towel removes bonded contaminants with virtually no effort.
The Nanoskin Autoscrub Towel is incredibly easy to use. Simply fold it in half (or into fours) and, using an approved lubricant like Nanoskin GLIDE, simply mist the surface and gently rub the towel back and forth and then side to side. Within seconds the paint will be silky-smooth and ready for waxing!
The fine grade Nanoskin Autoscrub Towel is ideal for vehicles that are new or well-maintained. The high-tech rubber polymerized coating will safely remove above-surface contaminants without scratching or dulling the finish.
12 x 12 inches
I have been using one of these for about the last year. I like it better than clay, it's easier, faster, and it lasts a lot longer. If you drop it all you have to do is rinse it out, whereas clay, you would have to throw the clay away. It's a little pricey but if you use it often I think that it will pay for itself.
Jay
