Clean Headliner
PRRAM
2014 Laramie Limited
If you have stains in your headliner then I recommend "Mothers Foaming Wash". If you try soap and water you will cause water stains.
I apply the Foam Wash to a terry cloth, rub the foam into the terry cloth so there are no suds. Then I gently massage the stain with the cloth. This product is basically a dry soap, all other products I have used detailing cars causes water stains in headliners. You don't apply a lot on the area. Small amount goes a long way.
https://www.amazon.com/Mothers-06410-Leather-Foaming-Cleaner/dp/B00B9W4HLQ
RT-SCAT
Adams carpet and upholstery cleaner is good stuff as well. Should give it a try! I've had good luck with it.
O.R.T.
Wessyyydddeee
As odd as this sounds for another option, Spot Shot Carpet Stain Remover also is a solid choice. Just used it to remove a grease smudge that was on an a-pillar of a Chrysler 300 that has the same grey cloth as our headliners. :happy107:
1Popeye
