help tried just about everything
jd-08-magacab
hannford California
Hemi 5.7l - D long block no egr no mds
I can think of to remove white epoxy road paint from my 08 dodge ram Laramie 2500hd mega cab I've went thru 4 clay bars witch work but how far should 1 bar go pressure washer don't do anything been working on it of and on when I get the chance also tried wd40 on the plastic inerfinders witch did a good job on that part not sure if I should do it on the paint or mirrors I've heard laqure thinner works real good as long as the clear coat is thick enough any one know of a better way
huntergreen
hopefully someone will have a better than mine, but i would ask a detailing forum,
Ramunit
I would try a 3M eraser wheel
averageguy
Belleville Mi
hemi
Be careful with the 3m wheel they can get hot if you get aggressive and burn the clear/paint. Trust me I know.
MADDOG
Not RamForum Staff
So this paint is on the paint? If you can't get it off with the clay bar or paint thinner (be careful, it will also take off the clear coat) it sounds like you will need to have it cut, buffed and polished.
Basically a little buffing compound on a random orbital sander/polisher, followed by some wax and polish is need.
