garner
- Nov 15, 2010
- 3,979
- 85
- Harker Heights, TX
- 2012
- Hemi 5.7
I use this but it has only been used like 2 weeks ago wiping down the truck with water before the car wash since the truck hadn't been washed in 3-4 months. But I would do a body panel from top to bottom and then I would spray it pointing down so hopefully the contaminants would run out with the water. And then I used it today wiping down the passenger side bedside before clay bar
But got the claybar done on the passenger side bedside and there was definitely something sticky on it cause even with the detailer and water sprayed on for lubricant it would stick to the body and would leave a white residue so I had to keep the water running on the bedside to get through those areas. And I had to use a lot of elbow grease for the stickiness to come off. I'll see if it removed the black stuff when the truck dries
