EWC88
I have a spot on my truck, bottom of the rear fender, were the paint split basically and surface rust started to form. I wanted to sand it and do a touch up paint on it so prevent anything make happen till I get her fully painted. Now I don't want it to look like **** either. Is there a way to just paint this area instead of doing whole panel?
I was thinking prime that area where it bare metal probably use a filler primer, then sand it to make it smooth. Scotchbrite a portion of paint around the crappy area, several light coats of paint, then same with clear.
My question is should I tape off a area so it's only a certain spot where it'll blend and if so how big? Problem is its right on the edge where the side is bending in to the wheel well.
