Recommendations for black exterior paint
Andrew09HEMI
Just used ONR for the first time and I'm blown away! I'll never use regular wash again it's that good. Crazy as I've been washing and detailing since I was 13 and this is leaps and bounds betters and easier.
Washed the wife's car as well cause I had the extra time!
Miss Blackened-heart
Los Angeles
That was on my list of things to try, so I'll be getting some this weekend. I tried meguires wash and wax. I was happy with it but wanted more shine.
RAM-pagingMN
Alexandria, MN
man so much info and recommendations out there for black paint. so i have a all black ram 2500, tons of swirls and light clear coat scratches. just ordered the porter cable 7424x, and now i need to find the right products. ill get a foam cannon too. what do i need to remove and make it shine? i hear a cutting compound, then black light from chemical guys? haha too much info and products out there!
Dirtyblackhoe
Thomasville, GA
I have always had amazing luck with an orange pad and Menzerna FG400. It cuts great and finishes out very good. I have used it as a 1 step polish and been very happy with my results.
Before
After
Door before
Door after
Entire truck when done
moparpeetie
south central PA
ONR? sorry...whats that? Did I miss something?
Andrew09HEMI
Got lazy didn't feel like typing it out, my bad! Definitely a fan of using it and can clean the whole truck in 35 mins, meaning in that time truck is clean and I'm done and inside.
SilverRam11
4.7 V8
I just got some optimum no rinse, any tips for best results? Do you rinse the car first? Or just wash and dry with the ONR?
bhonshell37
Washington
ONR can be used as waterless wash or rinseless wash. There are directions on the bottle. Rinseless wash requires plenty of quality microfiber towels. Yes you can rinse your vehicle first to knock off the large debris
Andrew09HEMI
What you should do is the Garry Dean method on YouTube. This seems to be the best method. I was careless this last time and didn't presoak the paint with onr diluted in a spray bottle, and I ended putting some small scratches in the roof and hood, but that's my fault for being careless. Look up the Garry Dean method on YouTube, it's the way I'll be doing it from now on to ensure you're not scratching or using dirty towels.
SilverRam11
4.7 V8
Thanks for the tip. I bought my truck used, it has scratches, and its silver. I'm not looking to have a perfect finish, but living in an apartment this actually will be an easier way to get a good wash done.
Andrew09HEMI
Got ya, then this is right up your alley! Its simple, easy and quick. Id still presoak the panels, it helps a lot.
ericwudi0830
Hemi 6.1
Try ONR for a rinseless wash. Best used with microfiber cloths
radikio
