Semi pro Detailer here!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
vinegar? CLR, few ideas.
HEMIRT
Manteca CA
I could try vinegar but I might be a little leery of CLR. Be my luck it would do some damage.
Laramie1997
Springfield, Missouri
1997 Ram/2013 Charger R/T Super Trak Pak
5.2 (318ci)/5.7 (345)
Vinegar and or lime away. Just watch where you drip.
Sent from my Infused Apple Torcher
RubberFrog
Start with a good wash, followed by a claybar. If you have any etching left from the spots use a glaze.
YoMoma
Iowa
I`ve got a question. I`m embaressed to say I "glug glug" then spray to make lotsa suds.
You on the other hand first add water to bucket then add a mesured amount of wash. You mix this by adding a little more water, correct? Or by hand with the sponge?
I think I get the wrong mixture of wash to water. Alot of times after my truck drys you can see through the window a film that hasnt washed off. This could also be partly due to the fact that my truck needs a wax job and the water isnt beading and running off the truck properly.
YoMoma
Iowa
Turtle Wax Brand Zip Wax car wash.
Stangshcky12
Oshkosh, WI
5.9 Cummins
When I detailed at my uncles dealership we had this thing that was supposed to mix water and soap right for you, it was slow and I hated it. I usually usually pour some in and fill it with the hose.
Your film might be because it's a Wash and wax soap
Only thing I could think of is make sure you start rinsing from the top of the truck and push the dirt and grim down
YoMoma
Iowa
This I do, but I wouldnt doubt if I`m using too strong an amount of wash vs water.
AJMAG
new jersey
$20 and a 30 pack of your beer of choice to whoever wants to detail my truck cause now thats summer is gone i have no motivation to even wash it let alone detail it :doh2::cheers:
Stangshcky12
Oshkosh, WI
5.9 Cummins
My dad gets mad that my brother and I both detailed cars and neither of us will wash his truck. I hate washing cars anymore lil
redrocket
2007 Ram 1500 5.7 4x4
i bought my truck used, and the idiot that owned it before me has swirl marks all over it. its a 2007 so the paints fairly new. its also red. i tried compound, glaze, ultrafine polish, claybar. theyre still there.!!!! any ideas on how to get rid of them?
The Assassin
B-more careful, Murderland
Are you doing it by hand, or using a machine? Check out our vendor Thompson Racing, for Adams Polishes. They will totally hook you up with what you need.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
redrocket,
Go to autopia.org and ask your question. This is a free worldwide professional detailer site that you can ask questions on or just read and increase your knowledge base.
Jay
