Stupid move any ideas?
Hughey79
Tonight I pulled the third brake light to replace the factory seal with a rubber one. Got down to the adhesive and the posts saying its on there is valid.
Thought Id soak it with some 3m adhesive remover and well crap. It started fading the brake plastic color on the back big time and got to the main edges.
Is there a trick, option, or something that can restore the normal look on the main side? Its not noticeable from the ground but standing in the bed you can see it along the top edge its hazy and lighter.
Tried a light polish and it didnt do anything. Thanks all.
bhonshell37
Washington
Can you post a photo of the problem?
H
Hughey79
Along the top edge
Here it is
H
Hughey79
Another
Corner
H
Hughey79
Heres the actual other
Meant to add this one
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
thats not going to polish out, looks like it got behind the lens, you can see if there is some between the seal and the lens that you can remove but otherwise that wont be going anywhere
Andrew09HEMI
You can wetsand that and reclear it. Or buy a new lens, shouldn't be expensive
Demon-HeMi
Houston
to me that doesnt appear to be clear, especially if he polished it
Andrew09HEMI
Hmm not sure then. It wouldn't make much sense to me, and I can be wrong, he couldn't wet sand and clear. Doesn't look like the color changed at all but rather the clear damaged
Demon-HeMi
Houston
i think there is a black coating on the back of the red lens to give it that dark ring, i think thats whats was removed here
Andrew09HEMI
Got ya! I'm not sure then but can't imagine they're expensive
H
Hughey79
Thats what I was afraid of. It got between them and the black on the back is no longer black. Obviously that doesnt matter though.
The extra you have. Is it brand new?
My other option was a later if light tint or vht thoughts?
Demon-HeMi
Houston
just get an aftermarket LED one, brighter and wont ever burn out
Johnnymac2k6
Ohio
2007 Ram 1500
First load of gravel in the bed and that little brake light imperfection that i can't even see will matter alot less ;)
