water spots on glass
jschreiber94
Maryland
whats the best way to remove the water spots from my glass on my 04. ive tried Mothers water spot remover for glass but it didn't do anything. just trying to get some input before I waste anymore money. thanks
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Ive heard like 50/50 water and vinegar mix...
WhiteExpress
Midland, TX
Clay Bar and/or polishing compound.
If you choose the compound, Don't use pressure, like ANY pressure.
Let the compound do the work!
Also, you can wax your windows once they're clean to help prevent this in the future.
jschreiber94
jschreiber94
Maryland
does it have to be any kind of compound like any certain cut or just plain old compound
jschreiber94
jschreiber94
Maryland
clay bar worked out good
clay bar worked great for removing the thick water spots on my back window thanks for the help guys
WhiteExpress
Midland, TX
I feel like I am clay bar'n my windows once a month. F*cking hard water!
Chewy
Bettendorf IA
V8
Pure vinegar and a Mr Clean Dry Eraser will work... I clay my windows all the time. I use Adams glass cleaner as the lube and then follow up with their glass sealant.
Pretty much any mild paint correcting polish can be used on the glass. Glass is MUCH harder than our clear coats so using this sort of polish is safe. It also means you don't have to have a special product just for your glass. It's just not necessary!
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Clay bar or a Nano towel.
Jay
