Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > 5.9 Common Rail
5.9 Common Rail
C-Codes
This is a discussion on C-Codes within the 5.9 Common Rail forums, part of the Dodge Ram Cummins Diesel Forum category!
To obtain C-codes perform a Gauge Cluster Check: hold trip and turn key to run. Gauge lights will turn on ...
Like Tree1Likes
  • 1 Post By Tryan
Reply
Old 08-29-2010, 03:49 PM   #1 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default C-Codes
To obtain C-codes perform a Gauge Cluster Check: hold trip and turn key to run. Gauge lights will turn on to verify function, sweep gauges will move through sequence to very function, codes will display in ODO.
INSTRUMENT CLUSTER FAILURE MESSAGE
Fault Code Description
01 Airbag warning indicator output circuit shorted.
02 Airbag warning indicator output circuit open.
03 ABS indicator output circuit shorted. .
04 ABS indicator output circuit open.
05 MIL indicator output circuit shorted.
06 MIL indicator output circuit open.
07 Wait to start indicator circuit shorted.
08 Wait to start indicator circuit open.
0B BTSI output circuit shorted or open.
22 Headlamp switch input circuit shorted.
23 Headlamp switch input circuit open.
24 Turn hazard switch input circuit shorted.
25 Turn hazard swiitch inpot circuit open.
27 Courtesy/dome output circuit shorted or open.
28 Glovebox/map lamp output circuit shorted or open.
29 Cargo lamp output circuit shorted or open.
40 Wiper switch input circuit shorted.
41 Wiper switch input circuit open.
42 Wash/beam input circuit shorted.
60 Passenger door lock switch input circuit shorted.
61 Passenger door lock switch input circuit open.
62 Passenger door lock switch input circuit stuck.
63 Driver door lock switch input circuit shorte.
65 Driver door lock switch input circuit stuck.
66 All door lock output circuit shorted to ground or voltage.
67 All door unlock output circuit shorted to ground or voltage.
68 Driver door unlock output circuit shorted to ground or voltage.
6C Driver cylinder lock switch input circuit shorted.
6E Driver cylinder lock switch input circuit stuck.
80 Incorrect odometer value found. .
81 Remote radio switch input circuit high.
82 Remote radio switch stuck.
A0 Internal module FLASH memory checksum failure.
A1 Internal module bootloader failure.
A3 Battery voltage open.
A5 TCCM messages not received.
A7 VIN checksum error.
A8 VIN previously stored.
A9 PCI bus internal failure.
AA PCM messages not received.
AB TCM messages not received.
AC ABS messages not received.
AD FCM messages not received.
AE ACM messages not received.
AF SKIM messages not received.
B0 RKE fob batteries low.
B1 RKE module communication link.
00 Done All Diagnostic Trouble Codes (DTC) have been displayed.
Sponsored Ad
Register to remove this ad.
__________________
Owner & Service Manuals for many years: www.scribd.com/lilfroger/shelf
lilfroger is offline   Reply With Quote
Old 01-05-2014, 12:35 PM   #2 (permalink)
Ram Year: 2003
Engine: Cummins 5.9
Default was looking everywhere for the c code list
thanks for the c code list for 3rd generation, my 2003 Cummins had a couple codes and this helped a lot
v/r SFC W US ARMY
03dr2500vin6 is offline   Reply With Quote
Old 03-18-2014, 07:41 PM   #3 (permalink)
Ram Year: 2003
Engine: 4.7
Default
I have code 06 what does it mean. Mil indicator output circuit open. Kind of lost on that one.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
nosu13 is offline   Reply With Quote
Old 07-25-2015, 11:21 AM   #4 (permalink)
Ram Year: 1998
Engine: 3.9
Default Cluster test
My speedometer and odometer doesn't work on my 1998 Dodge Ram, all other gauges work.I performed a cluster test, all the gauges moved and didn't get any codes? It had 199,237 miles when it stopped, any ideas. Thanks
pajeepman likes this.
Tryan is offline   Reply With Quote
Old 09-13-2017, 04:24 PM   #5 (permalink)
Ram Year: 2002 Ram 1500
Engine: 4.7
Default
Any clue what a6 is
Mikecollins is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
6.7 ODBII Error Codes lilfroger 6.7 Common Rail 3 08-29-2010 03:47 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
