hounddog
- Jun 2, 2012
- 397
- 103
- Charlevoix, MI
- 2017 laramie 2500 credit cab 4x4 cummins
- 6.7 Cummins
So, my '14 2500 6.7l with only 3800 miles is making a noise that has been described by others as "eggs frying" when it is idling. The noise is a popping and snapping sound. It's over the regular engine noise.
When it has been driving or gets warmed up it gets worse, not super bad but inside the truck you can hear it pretty well if you listen. Outside the truck it almost sounds like a light "ping" or knocking. As I drive the truck it gets worse and sounds like knocking. When I pull something heavy it gets very bad.
Also, when I let off the accelerator there is a second noise (kinda has the same sound but it's not the same) where there is non-random but intermittent noise that almost sounds like what I can best describe as an "electrical rattle" like either something is loose or some signal is being made into a short. (I know that's not it but I can't describe it any other way).
Trouble is I am not able to get audio/video, I've tried several times, but at least the diesel tech heard the same noises.
I've had it in a couple times and the tech has no idea how to fix it, chrysler tech reps have no idea.
Fuel pump was out of phase, fixed that but didn't help.
The second intermittent noise does seem to go away when I run the AC, but only when I'm not pulling anything.
I really hope someone has heard something like this because no one around here has any ideas.
