Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > 6.7 Common Rail
6.7 Common Rail
DEF usage ?
This is a discussion on DEF usage ? within the 6.7 Common Rail forums, part of the Dodge Ram Cummins Diesel Forum category!
Originally Posted by RyeThomas Also remember the dealer delivers these trucks without toping off, sad to say but you buy ...
Like Tree1Likes
Reply
Old 05-21-2014, 11:09 AM   #11 (permalink)
Ram Year: 2014 Outdoorsman
Engine: Hemi 5.7
Default
Originally Posted by RyeThomas View Post
Also remember the dealer delivers these trucks without toping off, sad to say but you buy a $40K-70K truck and they won't fill it.
yeah they do that with gas too. i've bought far to many vehicles then when i go to pick up the thing is right on empty, hell one time they had it so low i actually didn't even make it to a gas station. now i demand a full tank as part of the deal, if i had diesel i'd be demanding full DEF too
Sponsored Ad
Register to remove this ad.
Andy578 is offline   Reply With Quote
Old 05-21-2014, 11:52 AM   #12 (permalink)
statefan21's Avatar
Ram Year: 2009
Engine: 5.7L Hemi
Default
Our work trucks(F350 Diesel) which we drive cross country multiple times a year, uses about a gallon or so each trip. Unless we are towing of course. Do not let it run empty though. that will mess the engine up quick, fast and in a hurry
statefan21 is offline   Reply With Quote
Old 05-21-2014, 12:28 PM   #13 (permalink)
Stangshcky12's Avatar
Super Moderator
Ram Year: 2007
Engine: 5.9 Cummins
Default
My buddies 13 was going through quite a bit when he first got it
He had a computer update at the dealer and it started using much less
Not sure what he's actually getting mileage wise
The truck will go into limp mode if you run out or are very close to empty, it gives you multiple warning before it gets to that point
You wont really mess anything up, it just sucks to try to get it to a dealer to get it cleared
__________________
RamForum.com Moderator
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
Stangshcky12 is offline   Reply With Quote
Old 05-21-2014, 02:20 PM   #14 (permalink)
dsent's Avatar
Ram Year: 2012 2500HD 4x4 Crew Cab Laramie
Engine: 6.7 cummins diesel
Default
Hello Guys,
You do not have to fight with the dealer to get a full tank of DEF and gas.!!!
The dealers are getting paid by RAM as part of the PDI (pre delivery inspection process) to you the customer.
If they give you any kind of a hard time just remind them of the PDI Process.
My 14 Jeep grand Cherokee Eco Diesel had 1/4 of DEF when I saw my Jeep for the first time, I reminded them to fill it and I had no problem.
In my manual it says the 8 gallon DEF tank should last 10K when oil changes are due.
It should be part of you the purchaser as your process before you sign your name on the dotted line and take delivery to scrutinize every inch of the new vehicle and make the dealer aware of all defects!
I usually make a list and a drawing like the( rental car companies use to note damage) and get the dealer to sign it an make a copy for myself as part of the dealer form that they use "we owe"
The Jeeps are throwing different false codes relating to DEF tank and pump their is a TSB here
http://www.wk2jeeps.com/tsb/tsb_wk2_1801814b.pdf for a PCM Flash.
I am sure if the jeeps are having issues the RAM's are having the same problem check for a TSB like the one above.
__________________
Regards
Don
Due to economic hard times the light at the end of the tunnel will be turned off until further notice!!!!!
dsent is offline   Reply With Quote
Old 07-20-2014, 12:54 PM   #15 (permalink)
Ram Year: 2014
Engine: Cummins
Default
I bought my truck brand new with a full tank of DEF. I drove about 6900 miles which was almost all highway, and my DEF was just on the bottom side of 1/4 tank. I didn't tow anything during that time. I got a 2 1/2 gallon jug from the dealer for ~$30 and it put me back at almost 3/4 tank.
BennyHanna is offline   Reply With Quote
Old 07-20-2014, 02:32 PM   #16 (permalink)
jadocs's Avatar
Ram Year: 2014
Engine: 6.7
Default
Told my dealer to fill it with DEF as well when I bought mine. No issues.
__________________
Using Tapatalk
jadocs is offline   Reply With Quote
Old 08-23-2014, 02:42 PM   #17 (permalink)
Ram Year: 2013
Engine: Cummins Turbo Diesel
Default
I have a 2013 2500 and I get about 7000 miles per tank of DEF. FYI, DEF is MUCH cheaper at the pump as opposed to buying it in bottles. It is currently $2.79/gal at my local truck stop. NOTE: You will have to pull into the commercial pumps to get DEF. They don't offer it in the "regular" pumps.
Matt0676 is offline   Reply With Quote
Old 08-23-2014, 09:49 PM   #18 (permalink)
JoshNHRA's Avatar
Ram Year: 2014
Engine: Cummins 6.7
Default
My 2014 5500 get about 6000KMS per tank.
__________________
2014 5500 SLT Service Truck
JoshNHRA is offline   Reply With Quote
Old 08-23-2014, 11:59 PM   #19 (permalink)
jadocs's Avatar
Ram Year: 2014
Engine: 6.7
Default
I have 4k plus miles so far and I'm on 1/2 tank.
__________________
Using Tapatalk
Old 09-17-2014, 05:32 PM   #20 (permalink)
Ram Year: 2015
Engine: Cummins Diesel
Default
How many gallons is the def tank?
Chipper7 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
8 speed transmission usage question kenwitter Engine & Performance 3 09-10-2013 06:12 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
