Front leveling kit for 2016 2500 4x4
jmyork88
New Orleans, LA
5.7L Hemi w/eTorque
Any recommendations on what brand? I dont see much that say 16 compatible but im assuming its the same as 2015??? Should i wait or go with 15? Do i upgrade the shocks and for uniformity should i change the rears?? (sorry for the amount of questions)
NWRQC
jmyork88
jmyork88
New Orleans, LA
5.7L Hemi w/eTorque
Thanks for your response. So im assuming these are way better than adding $100 spacers lol
MADDOG
Out Exploring Arizona
The leveling kits for a 2014 2500 & up will fit your truck.
Spacers work very well to level a truck. They don't cost a lot compared to a suspension lift, they are easy to install and they don't wear out. I kept my stock shocks when installing the Tuff Country 2" level on my 2500. There is still plenty of travel left in the shock so I am not concerned about premature failure of that component.
jmyork88
jmyork88
New Orleans, LA
5.7L Hemi w/eTorque
I see some come with a pair of strut relocation brackets.....sound right? says no new strut needed
1500ram12
5.9L Cummins
Some come with shock extensions and radius arm drop brackets
MADDOG
Yes, they come with or without a shock relocation bracket.
I used Tuff Country's 32909 kit with the bracket which is why I was able to keep my stock shocks.
NWRQC
Having had both, I will say yes.
I bought my truck with a 2" spacer lift and got tired of feeling every small crack and bump in the road. I swapped those out for a set of Thuren springs to improved the ride.
jmyork88
jmyork88
New Orleans, LA
5.7L Hemi w/eTorque
Went with the Tuff Country 2" spacer with relocation brackets. I love it and with the spacers ride quality remained factory feel. For the price, you can't beat it and it totally changes the look. Very happy! Thanks for all the input!
Power247
High Point, NC
6.4 HEMI
Looks good man
Greg
2012 | 2500 | CCLB | Custom MCC by Double R Diesel
homebrew
Cummins
im debating on a full lift or a level. I wanted to ask how far off centered the front axle is after doing a level?
