Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > 6.7 Common Rail
6.7 Common Rail
RDS Auxiliary Fuel tank/Tool box
This is a discussion on RDS Auxiliary Fuel tank/Tool box within the 6.7 Common Rail forums, part of the Dodge Ram Cummins Diesel Forum category!
Is there a size a little wider do you don't have so much space between the bed sides and the ...
Like Tree4Likes
Reply
Old 07-13-2016, 01:47 PM   #11 (permalink)
Mallardsx2's Avatar
Ram Year: 2016
Engine: Cummins 6.7
Default
Is there a size a little wider do you don't have so much space between the bed sides and the box?
Sponsored Ad
Register to remove this ad.
__________________
2016 RAM 6.7L CUMMINS BIG HORN
Mallardsx2 is offline   Reply With Quote
Old 07-16-2016, 01:13 PM   #12 (permalink)
Jackfate's Avatar
Ram Year: 2016 1500
Engine: Hemi 5.7
Default
May I ask the total cost of this project?
Jackfate is offline   Reply With Quote
Old 07-18-2016, 11:55 AM   #13 (permalink)
Arctic-Rodz's Avatar
Ram Year: 2014 2500
Engine: 6.7L Cummins
Default
you might find another one that will tuck up closer to the sides but I find those sides pretty handy. I keep a spare gallon of windshield washer fluid in there. On the driver's side is where the feed tube goes down to the filler neck so you do need that space.
I paid about $1000 for everything. Including the installation and bedliner on the tank/tool box. Buddy works for at the installation place so they hooked me up pretty good!
__________________
-2014 Ram 2500 Crew Cab Tradesman Cummins 4x4
-2013 Triumph Tbird Storm : With MODS
-2014 VW GLI Autobahn
-1997 Camaro Z28 30th Anniversary Edition : With MODS
Arctic-Rodz is offline   Reply With Quote
Old 07-18-2016, 11:59 AM   #14 (permalink)
Ram Year: 2014 2500
Default
Can you just hook this up to the fuel filler line and have a 1" valve to open up and let the fuel feed into your tank that way instead of buying that electronic feeder thing? Also, Is there any concerns of that breather being under a tonnneau cover with the sun beating down on it getting those diesel fumes vaporized and risk explosion?
Did you get a hose and a pump fro it for filling up a tractor? If so, which one did you buy?
It would take A LOT of vapor to fill that area. I typically open the tonneau cover several times per trip for luggage and stuff. I was concerned with my luggage smelling like diesel but I haven't experienced it on any of my trips. @ 100+ degree weather either. So its been good.
I only have a valve with an electric butterfly which allows fuel to drip down to the main tank. It also has a secondary hand valve which closes the fuel supply if you need to service that electric valve.
I haven't used my top tank to fill up my tractors. Since i use regular fuel to fill my truck. I just carry a couple of spare plastic 30gallon tubs when i need to haul fuel for my tractors (red dyed) and use a Northern Tools purchased transfer pump which powers itself from the tractor battery. Pretty handy.
So my tank is only used to fill my truck.
__________________
Old 08-08-2016, 01:02 PM   #15 (permalink)
drittal's Avatar
Ram Year: 2013
Engine: 6.7
Default
You could, but this tank is bigger than your fuel tank so you will either have to stop and wait for main to to be filled by gravity feed, or pull over again to shut it off before you overfill the tank. A friend of the family does it this way but has a 28g tank. He gets down to 1/4, stops and opens the valve and drives off.
Run the vent line outside the bed
Sent from my SM-N900V using Tapatalk
drittal is offline   Reply With Quote
Old 08-22-2016, 06:40 PM   #16 (permalink)
drittal's Avatar
Ram Year: 2013
Engine: 6.7
Default
My father in law's RDS tank. He mounted a 20gpm pump inside the tool box area with a hose and dispenser. He leaves the switch at the pump on and runs a relay with a toggle switch inside the cab to turn it on and off. 51 gallons.
My father's set up. This one is plumbed into the filler neck with a small diesel fuel pump with an in line filter with a switch in the dash. 58 gallons.
Old 12-26-2016, 04:12 PM   #17 (permalink)
Ram Year: 2014
Engine: Pentastar V-6
Default
I know I am digging up an old thread but how does this one fit? The measurements on NT website show it being 1" too wide to fit between the wheel wells.
dewey405 is offline   Reply With Quote
Old 01-26-2017, 08:45 PM   #18 (permalink)
Ram Year: 2014 2500
Default
my tank fits perfectly. It doesn't touch the wheel wells, it sits right behind them.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
32 Gallon Fuel Tank?? CMil527 Exterior 31 05-21-2015 12:30 PM
fuel tank help reek Tech Info 3 05-15-2015 01:19 AM
small fuel leak at fuel tank RAtmosphere 5.9 Common Rail 1 02-05-2014 04:22 PM
Fuel tank Marc1982443 Exterior 14 06-20-2013 10:04 AM
Fuel tank Q? srt8dork General Discussions 21 11-19-2010 02:36 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
