I have a 2016 Powerwagon with less than a thousand miles on it, and I have the stock factory Wranglers on it. My tire pressure warning indicator came on yesterday. My dashboard system tells me that my tire pressure for all 4 tires is 81 to 82 pounds. in checking the sidewalls of the tires, they indicate a max PSI of 65. The VIN plate on the driver door frame indicates 60 PSI in front and 65 PSI in rear. It's my understanding that HD truck tires should have a higher PSI, but that may be bad info. I know the warning system will activate if the tires are overinflated, as I experienced this on my previous Ram TRX, when I had a brain fart and overinflated the tires. With that being said, and before I go deflate my tires to where I think they should be according to the info on the tire and the VIN plate on the door frame, what PSI should I put in my Powerwagon factory tires for basic everyday driving....?
