2015powerwagon
- Mar 2, 2015
- 5
- 9
- 2015
- 6.4
Looks great man! If you do need to haul and you want to level pick up some airlift 5000 bags and the truck will always be level!
Flex as in when you're offroad going over rocks and stuff?These bags will tear if the suspension flexes like the power wagon is designed to do. I believe daystar or carli is the only manufacturer of an airbag that can be used on a power wagon and allow it to flex.
Just got the mufflex for my 2015 6.4. I haven't rally got a chance to check gas mileage, not believing the hype on that one either.. I have just now 4000 miles on my truck and gas mileage seems to be improving as truck gets broke in….. the sound from stock is what makes it worth it, and honestly does feel like it has a little more get up and go….
Have you noticed anything negative when it cuts the cylinders to 4 on freeway type cruising? With the stock exhaust I hear a little rumble/drone. I'm curious if mufflex is same, better, or worse.
Thanks, D
