New 75 power wagon owner
lostboy03
Lemoore CA
360 cid
Hello,
I am a new Power Wagon owner. I recently purchased a 1975 with a 360 cid engine and 4 wheel drive. I have a couple of questions: one, I will start to work the timing on the engine and get it advanced to about 8 degrees. When I secure the distributor I will check the timing again. It is where I want it and after a few second the timing will advance itself to where I cant see the timing mark. Please help. Also if anyone has the same vehicle as me can you please take pictures of your vacuum system for me. I am chasing what I thing is a vacuum leak and those pics would help immensely.
White Beauty
Moncton, NB
2011 Ram 1500 SLT
Pics. Or no answers. Hahah
Sent from my SGH-I747M using Tapatalk
NYCruiser
Yonkers, NY
If you are having vacuum problems, the timing issue is probably involved.
Check out the vacuum advance on the distributor. Its usually connected to a ported vacuum connection on the carburetor. If it is connected to manifold vacuum you will get constant advance whenever there is vaccum present.
As I recall, we used to disconnect and plug the vacuum advance line with a bolt when setting the timing on these.
There is a diaphram inside of it that can leak and cause vacuum problems too.
Edit - would love to see a pic!
PCA4208
Albuquerque, New Mexico
Yeah vacuum advance need to be plugged before adjusting the advance. NYCruiser is also correct that it needs to be routed to a ported manifold vacuum. I think the timing would need to be at 15 BTDC, at least thats what the underhood tag on my 79' says. But if it runs good at 8, then thats fine.
WhiteExpress
Midland, TX
Well, I'm excited to see pictures.
Sounds like everyone has already stated to disconnect the vacuum line.
L
lostboy03
Lemoore CA
360 cid
It seems like the distributor is advancing with an rpm advance but the engine is staying at idle.
Brakelate
South/Central Utah
You sure it is a stock vacume activated advance? Seems very likely over the years that someone might throw in an performance unit with a mechanical advance or even a electronic one.
Internal spring could go in that case, or someone buggered it all up to start with before you got there so bad that finding a baseline to begin with is difficult?
PCA4208
Is this what the front of the carb looks like? If so these are your vacuum ports.
L
lostboy03
Lemoore CA
360 cid
No. It is an after market carb. An edlebroc or carter I belive. I will try to take a picture of it tomorrow.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Does your carb look like this?
If so that's the Carter Thermoquad, should have been stock on that engine in 75.
L
lostboy03
Lemoore CA
360 cid
20131230_050145_LLS_zps3e0tuveo.jpg.html
There it is. It looks like the stock 4 barrel carter and has an electric choke.
If the photo dosnt work out here is the web adress:http://s1315.photobucket.com/user/j...t=3&o=0&_suid=1388411472089031379542179310204
L
lostboy03
Lemoore CA
360 cid
I am starting to think that a new distributor would fix the problem as stated befor. Any thoughts?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
The picture you posted looks more like a Rochester Quadrajet, but upon looking on google, I don't think it is. lol
Not sure what that carb is, unless it's a different variant of the QJ.
And it's quite possible a new dizzy will fix it, but did you do the timing again with the vacuum advance unplugged or what?
L
lostboy03
Lemoore CA
360 cid
I did the timing unpluged, pluged and pluged with a screw just to cover all bases.
PCA4208
That carb looks like an Edelbrock carb. Based off the quadrajet. Quick google search can help witht he vacuum routing.
PCA4208
On the distributor, have your checked the magnitic pickup for air gap or if its loose? if its loose, it could mess up timing to a point.
