Anyone know the part number for the brackets that hold the actual center console together on the left and right sides towards the rear
CONSOLE BASE FRONT BRACKET - MOPAR (55365120AB)
CONSOLE BASE REAR BRACKET - MOPAR (55365121AD)
REAR DUCT - MOPAR (55056931AB) <- Installs onto front bracket to adapt on a crew cab.
The screws for the sides of the console are M6 bolts.
I pulled the nut plates out of the two that held the drawer in. They pop out to the front, I used a pick tool to pull them and then snap back into the console holes.
Also a couple of nut plates for the front bracket with screws or you can do what I ended up doing and use a couple bolts and nuts like the OP did and I did. Trying to find the M8 Nut plate that snaps in so I can install the two M8 bolts that came out.
