2015 Center Console Swap DIY
Jkieffer
Do you have the duct under your jumpseat?
Cesar592
3.6 pentastar
not only is the folding seat without outputs of a / c but the new console brings the ducts and I want to have this mode as factory but I do not know what parts I need to be able to carry this
Jkieffer
On my express I had two transition pieces. One was a short connector that went from the console to the one that came off the dash. My express had a punch out and a long curved piece fit joined the duct behind the radio bezel. (#4) was the hard piece for me. I don’t have the part number but Benny with all mopar part here on forum can help. 55056931AB (#7) is another part
Cesar592
3.6 pentastar
ABBB6DC9-2751-484A-AB51-8286CAA1F869.png this is the part that I need and the other you say is the number 7 there is some other part that as for the screws that was what you needed
Jkieffer
Do you have number 7 in this picture?
Are you talking about the bolts that hold the console to the brackets that mount to the floor.
Cesar592
3.6 pentastar
the bolts that hold the console ok then I just need those two parts and it's all I hope everything is plug and play I would not want to cut cables
Cesar592
3.6 pentastar
the brackets that mount to the floor are just one or two pieces I really do not know if I get the brackets that part number
Jkieffer
Jkieffer
Console-Console Base Rear Bracket 55365121AD
Console-Console Base Front Bracket 55365120AB
Bolts you can get number from Benny at all mopar parts. Or source at Lowe’s. / Home Depot
Cesar592
3.6 pentastar
I did not have the inverter but looked like I had the wiring stored behind the dash. My jumpseat had the USB and aux plug so I pulled out the 12 volt and used the cubby with the flat cover I had on the right side and cut a hole with a dremel tool to mount. Took to USB out of the original lower front panel and put in the new cup holder and relocated the power under the shifter knob with some more cutting. Now I have rear power, armrest power, and dash power as well as 2 USB's and aux input and fully functioning rear air. A lot of extra parts.
how did you run the usb and aux work perfectly cut or spliced some cables looks very good i think i will have to do it you would help me with this
Cesar592
3.6 pentastar
[QUOTE = "Jkieffer, publicación: 1563380, miembro: 53670"] Bueno, este fin de semana finalmente tuve suficiente valor para cortar en la caja de aire inferior e instalar el aire trasero y la consola central. Gracias Benny y todo el resto que me dieron la información.3eb9eb210d308c42bec1a90a564c5db4.jpg916442dc91bc8b29aa112a5bc93e72c1.jpg8912e6c0b6ab5b92f9674962d29389fb.jpg891dd0232bee1db762c4825534033e89.jpg
Enviado desde mi iPhone usando Tapatalk [/ QUOTE]
sorry I could not add the pipe to the hvac I'm trying but I do not know how you think you can help me or any recommendation
78Staff
US Navy Veteran
NE Florida
I searched the thread but only saw one reference to quad cab - do I have to get a quad/regular cab specific console, or would a crew cab console work in a quad cab? I realize the ductwork wouldn't exist, but as far as physically mounting, would it work?
00R/T
CT
It should. I have a console with vents in my regular cab.
WTM75
Upstate NY
3.6 Pentastar
They seem to be the same. When I was looking for a console, the only difference between a crew cab & a quad cab was the HVAC ducting. If you have a quad cab and get a crew cab console, the duct is very easy to remove if you want to.
78Staff
US Navy Veteran
NE Florida
thanks guys, I am tempted to do this. My buddy has the console in his, going to drive his and decide. I had it in my previous truck (F150), and had the shifter in the console as well, I would probably like that setup in my Ram also :).
Jkieffer
Really easy to do and one of my favorite mods
